Co-pilot gets sick, stewardess helps land airplane
Old June 24th 10, 01:36 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Default Co-pilot gets sick, stewardess helps land airplane
On 23 jun, 23:55, Mxsmanic wrote:
Hatunen writes:
Again you display your actual lack of knowledge and willingness
to display it in public. First, there is no FAR prohibiting the
demonstration or practice of doing spins.
Spins must be permitted for the aircraft, and regulations permit them (and
other aerobatic maneuvers) only under certain conditions. In this case, the
Cessna 150 may be spun only after certain modifications are made (since 2009),
in part to prevent maximum rudder travel from interfering with the elevators.
Yes, I have the AD in front of me.
Better start reading that AD.
a. Not all Cessna 150's are affected by this AD, just the ones with a
swept tail.
b. It has nothing to do with the rudder interfering with the elevator
but the head of rudder stop bolts got hooked.
Old June 25th 10, 09:46 AM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
On 24 jun, 23:42, Mxsmanic wrote:
writes:
swept tail.
That is, seven out of every ten 150s built, essentially everything after 1966
or so. That's a fascinating detail.
Important enough if you own a C150.
"... such as contact between the rudder and the elevator."
Nope. Read again.
Will all of these details fit on the head of a pin?
Reading and understanding details of ADs is part of aviation. The same
aviation you claim having an interest in.
Old June 25th 10, 12:06 PM posted to rec.aviation.piloting,rec.travel.air,rec.arts.movies.past-films,rec.arts.tv,alt.gossip.celebrities
Mxsmanic
writes:
Nope. Read again.
Done. The text hasn't changed.
Old June 25th 10, 01:49 PM posted to rec.aviation.piloting
a[_3_]
Default Co-pilot gets sick, stewardess helps land airplane -- dancing tothe MX tune
writes:
swept tail.
Nope. Read again.
You're all dancing to the MX tune, of course. I kept the initial title
so the music could continue, but reduced the newsgroups to only RAP. I
don't want to share the fun over a half dozen newsgroups.
Pilot nearly crashes in IMC, Controller helps pimenthal Piloting 32 September 27th 05 01:06 PM
Aviation Conspiracy: Toronto Plane Pilot Was Allowed To Land In "Red Alert" Weather Bill Mulcahy General Aviation 24 August 19th 05 10:48 PM
2 pilot/small airplane CRM Mitty Instrument Flight Rules 35 September 1st 04 11:19 PM
non-pilot lands airplane Cub Driver Piloting 3 August 14th 04 12:08 AM
Home Builders are Sick Sick Puppies pacplyer Home Built 11 March 26th 04 12:39 AM
