On Jul 27, 4:25*am, RN wrote:
Looking for information and feedback from anyone who has found a good method or source for printing or having printed replacement placards for an aging glider when no longer available from the manufacturer. John To replace the printed vinyl type adhesive placard I scan the copies in the POH or similar or take a photo of the orgiginal and load into Adobe InDesign or Illustrator as a background image and then lay out a new one on top of that. Spend far too much time tweeking them to look exactly like the originals (with logos and illustrations) because even if nobody else notices I will. Email off the PDF to my local FastSign store to print on their special printer (UV stable and robust inks) on adhesive vinyl and have them laminate a top layer over that that as well. Lots of time wasted but $30 or so out of pocket for a letter size sheet of placards. If you do want to use a sign store talk to them ahead of time about what file format they prefer/can handle. Cut vinyl lettering is not an option for small decals. The cutters have problems cutting small lettering and there are other problems. One of the things I've noticed that just trashes several types of printed factory placards is suncream. Especially where you might have suncream on your arms and it rubs on the decals. Laminating the replacement decals is good insurance agains this even if using a relatively robust ink. Darryl |
Placards | bildan | Soaring | 3 | May 9th 10 07:54 PM |
Making Placards | Charlie | Home Built | 13 | December 7th 06 03:37 AM |
Replacing innertubes without replacing tires? | Ben Jackson | Owning | 28 | November 6th 06 04:54 PM |
Replacing Cockpit placards | toad | Soaring | 9 | March 28th 06 03:04 PM |
what placards are required? | Dave Butler | Owning | 3 | June 3rd 04 09:03 PM |
