Aerotow takeoff with Cirrus, aileron rudder use
Old July 29th 10, 12:31 AM posted to rec.aviation.soaring
Andy[_1_]
Default Aerotow takeoff with Cirrus, aileron rudder use
On Jul 28, 3:46*pm, akiley wrote:
A little follow up for clarification. *I can't figure out what's more
important, staying behind the tow plane or trying to level the wings
with rudder during the initial roll. *(assuming ailerons are mostly
useless at this slow speed) It seems, at least on the initial roll,
that you can't always have it both ways. *
There isn't a conflict here. The rudder input required to raise the
wing is a rapid and brief pulse input that has no significant affect
of the lateral displacement of the glider. You want to get a
significant yaw rate but not a large change in direction. (Stomp on
the rudder and almost immediately bring it back to center)
Once the problem of the wing drop is corrected the increasing speed
and aileron control allows normal use of the rudder to track behind
the tug.
(Never flown the Cirrus but no stranger to use of rudder to raise the
wing on other types)
Andy (GY)
Aerotow takeoff with Cirrus, aileron rudder use akiley Soaring 17 July 29th 10 12:26 AM
I have problem. I correct the aileron the wrong way at takeoff Derek Copeland[_2_] Soaring 11 January 24th 09 05:56 PM
I have problem. I correct the aileron the wrong way at takeoff Todd Soaring 18 January 21st 09 12:19 AM
I have problem. I correct the aileron the wrong way at takeoff bildan Soaring 3 January 19th 09 08:04 PM
I have problem. I correct the aileron the wrong way at takeoff Doug Hoffman Soaring 0 January 19th 09 05:38 PM
