On Aug 19, 12:10*am, sisu1a wrote:
BTW ADS-B products used in contests are going to be "interesting" for the poor CD to deal with, ... not just worry about somebody getting weather reports. I'd expect Flarm to have that though out given their existing "stealth mode" and logging of that mode setting. Couldn't a pilot just have 2 Flarms, 1 to turn stealth mode logs in with and a separate one to leach with? -Paul You can always try to sneak prohibited equipment into your glider in a contest - like an artificial horizon, XM radio weather, etc. Be prepared to get penalized if you get caught. I do wonder whether contest rules eventually will require pilots to disable ADS-B receivers that don't have a contest mode - or will just accept the leeching, "heads-down" and stealth (turning off your ADS-B transmitter) behavior that would result from broad adoption of technology that lacks a contest mode. Another argument in favor of PowerFlarm for competition flying. 9B |
Trig TT21 transponder draws only 125 mA! | Steve Koerner | Soaring | 5 | March 15th 10 09:59 PM |
TRIG TT21 Transponders | Tim Mara[_2_] | Soaring | 12 | September 26th 09 02:01 AM |
Trig TT21 Transponder receives FAA TSO approval | Paul Remde | Soaring | 12 | September 19th 09 02:47 PM |
Trig TT21 in Experimental Aircraft | Paul Remde | Soaring | 5 | July 5th 09 03:15 AM |
Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 04:38 PM |
