On 8/19/2010 9:28 AM, SoaringXCellence wrote:
Artificial horizons are banned because cloud flying is not permitted in contests. It's not permitted in controlled airspace the USA at all unless the glider is IFR equipped and the pilot has a glider instrument rating; which is possible by the regulations, but I've not figured out how to do the practical test! The missed approach would be interesting. Cloud flying in Class G airspace is technically permitted, but probably an unwise activity. I can understand that cloud flying is banned, but banning an instrument that could save your life because it might be used to violate the rules sounds like a really crazy idea. -- Mike Schumann |
Trig TT21 transponder draws only 125 mA! | Steve Koerner | Soaring | 5 | March 15th 10 09:59 PM |
TRIG TT21 Transponders | Tim Mara[_2_] | Soaring | 12 | September 26th 09 02:01 AM |
Trig TT21 Transponder receives FAA TSO approval | Paul Remde | Soaring | 12 | September 19th 09 02:47 PM |
Trig TT21 in Experimental Aircraft | Paul Remde | Soaring | 5 | July 5th 09 03:15 AM |
Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 04:38 PM |
