Trig TT21 Transponder ... reports?
Old August 21st 10, 04:38 AM posted to rec.aviation.soaring
Mike Schumann
Default Trig TT21 Transponder ... reports?
On 8/20/2010 9:46 PM, Eric Greenwell wrote:
On 8/20/2010 9:25 AM, Mike Schumann wrote:
The ADS-B Ground Station roll-out is moving forward at an accelerating
rate and should be completed Nation Wide by the end of 2012. It is
fully funded and all the necessary contracts are in place.
The vast majority of the country will have coverage above 1,800 ft.
See
http://www.faa.gov/about/office_org/...cast/coverage/
I have no financial interest in any of this.
Mike, with the way my newsreader works, it would be a lot easier to
follow the meaning of your posts if you included at least a paragraph of
the posting you are replying to. Thanks!
Sorry. This was in response to Andy's post claiming that the ADS-B
ground station roll-out would take 10-20 years and wasn't even funded yet.
Mike Schumann
Old August 21st 10, 06:11 AM posted to rec.aviation.soaring
Andy[_10_]
On Aug 20, 8:38*pm, Mike Schumann
See
http://www.faa.gov/about/office_org/...s/ato/service_....
Sorry. *This was in response to Andy's post claiming that the ADS-B
ground station roll-out would take 10-20 years and wasn't even funded yet..
Mike Schumann
Thanks for the map - pity they only intend to cover many of the places
I fly in the west at above 18,000'. I remain skeptical that it'll be
done in 2 years, but we'll see.
How's the coverage down low on the White Mountains, where there is a
big converging traffic issue? Is it line of sight or can it get around
mountain ranges?
9B
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 09:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 02:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 02:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 03:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 04:38 PM
