On Aug 20, 8:32*pm, Mike Schumann
wrote: On 8/20/2010 2:11 PM, Darryl Ramm wrote: On Aug 20, 8:33 am, Alex *wrote: On Fri, 20 Aug 2010 07:14:01 -0700, Andy wrote: draws 0.8 amps @ 12v I've not been near an airfield for 10 years now, but are there no advances in solar power/battery technology since then that improve a glider's power supply? What is a typical glider's current requirement? -- Alex On Aug 20, 8:33 am, Alex *wrote: On Fri, 20 Aug 2010 07:14:01 -0700, Andy wrote: draws 0.8 amps @ 12v I've not been near an airfield for 10 years now, but are there no advances in solar power/battery technology since then that improve a glider's power supply? What is a typical glider's current requirement? -- Alex With gliders we fly you cannot easily stick solar panels over large areas of the glider because of cost and critical aerodynamic concerns and concerns about solar heating the underlying composite structure. There are specialized solar project exceptions. The manufacturer who dominates solar panels for gliders today is Strobl (http://www.strobl- solar.de ) and their panels are available preinsalled from all leading glider manufacturers or as add-on for a large number of gliders. See my blog athttp://www.darryl-ramm.com/2007/01/strobl-solar-panels-for-sailplanes/ for what a retrofit kit looks like. They typically deliver 15-30 watt maximum for several thousand dollars outlay. The Stobl systems use crystalline wafers in a semi-flexible ETFE (hey that what is used on Trefzel wire, oops another thread...) type plastic encapsulation. Likely all hand-built. The panels are attached with 3M ultra-high-bond double sided tape. Some installations will have molded in recesses for the panels some use hand applied filleting, some wedge trim strips around the panels. The crystalline cells give relatively high efficiency even with only partial fill factor on the panels. Other options emerging might be to use amorphous thin film panels but you are typical starting with low efficiency. I have the larges set of Strobl panels I can get on my ASH-26E engine bay doors that gives a peak spec of 30W (2.5A @ 12V). The actual delivered power is *much* lower. And you should rely not plan on solar panels to significantly boost battery capacity for a single flight as output drops dramatically under cloud streets, overcast sky etc. I really like the Strobl panels but it may be more useful/safer to think of them for use for ground charging of a tied down glider (e.g. some airports have issues with separate panels near the aircraft when tied down) and as a way of stretching capacity over several days when usual ground charging infrastructure is not available. Although it obviously varies widely a typical power consumption number for a glider avionics is roughly around 0.8 amp (as Evan noted his is) for what I am guessing is a typical setup of C302 style computer, a PDA, and VHF radio. Owners should measure and calculate the loads in the glider and estimate the battery capacity needed or run time available from the batteries they have. Do not just divide the nominal "Ah capacity" by amp load, especially at higher loads, you need to use the discharge curves data from a manufacturer to estimate the available run time of a battery at a particular load (most good VRLA batteries are close enough to use another manufacturers spec sheet for a similar sized battery). Transponders (and their encoders) used to be considered a large power hog. And in the days of horse drawn buggies, steam locomotives and traveling wave tube amplifiers etc. they were. While they are much more efficient nowadays, you do need to make sure they fit within a ships power budget. Modern transponders range in power consumption from ~0.5A for a Becker 4401 175W and ACK A30 encoder to around ~0.3A for a Trig TT21 (with built in encoder). Transponder power consumption will vary depending on interrogation rates and temperature (for the encoder heater). i.e. The Trig TT21 uses less power than large PDAs like the iPAQ 4700. The numbers here are realistic for typical glider operations. The NavWorx ADS600-B specs implies it consumes 0.8A at 12V. I have no idea if this is accurate or not, it may be less in practice. Today you need a separate display with third party software to get traffic information/warnings from the device, so guess around 0.45A (e.g. for a iPAQ 4700 PDA dedicated to the UAT data display). Most gliders have some combination of one or more "7Ah" or "12Ah" VRLA batteries. So to give a rough idea of maximum run time from typical single batteries ... (These number are very rough, I don't have my discharge spreadsheet handy that will do this properly, but they give the flavor.) 2.0A load = guess of typical glider load + NavWorx ADS-600B + iPAQ 4700 for UAT traffic display @2.0Ah load a typical "7Ah" VRLA battery ~ 2.7 hours @2.0Ah load a typical "12Ah" VRLA battery ~ 5.2 hours --- Since one scenario is people with Mode C might go UAT vs. buy a new Mode S/1090ES capable transponder. A UAT is does not make a glider visible on TCAS, so if you fly near airliners or fast jets that transponder is a good idea. If you do not then just look at the numbers above) 2.5A load = guess of typical glider load + Becker Mode C + ACK30 + NavWorx ADS600-B + iPAQ 4700 for UAT traffic display @2.5Ah load a typical "7Ah" VRLA battery ~ 2.2 hours @2.5Ah load a typical "12Ah" VRLA battery *~ 4.1 hours --- All these are numbers are for effectively fully discharging the battery, you should really not plan on running down batteries this much on typical flights and having no safety margin. Some fudge (20%) should be deducted from these numbers for typical battery aging. For very cold flights (e.g. wave) then maybe halve these run times. And again do the real calculations for your actual setup. How much battery capacity do you need? My longest flight was 8-9 hours (in my old glider with no solar panel). A typical "serious" XC flight for me is around 5-6 hours. This all assumes the the NavWorx ADS600-B nominal 0.7A spec at 14VDC nominal (i.e. 0.8A at 12VDC) is *correct. It could be lower in practice. I'm not even sure why we are down this rat hole. None of this is not a slight on NavWorx, their UAT transceiver was not designed for the glider market, NavWorx does not claim it is intended for the glider market, or target any marketing to the glider market AFAIK. And issues with incompatibility with all existing (Flarm serial display protocol based) glider traffic display/software, lack of any third party traffic display/warning product tuned for glider specific type environments (esp. gaggles), lack of traffic collision/alert warning from the receiver box etc. are also issues for use in the glider market. I am convinced that a company who wanted to target the USA glider marker with a UAT product would have no deep technical issues addressing these items, or reducing the power consumption significantly today. The issue is justifying a business case for a company to do that for the intersection of the relatively small USA UAT market and the much smaller USA glider market. BTW some older slides and spreadsheets on glider batteries at http://www.darryl-ramm.com/glider-batteries/but I don't think these make much sense unless you've seen me present them. I originally made that presentation because of confusion around batteries and transponders. That confusion went both ways, people way under capacity for their loads (BTW interestingly often with PDAs and ClearNav type devices not just transponders) and people thinking they could never use a transponder, often based on out of date info on transponder power requirements. Darryl Has anyone thought about using a very small ram air turbine to provide power in a glider? *How big would such a turbine have to be to generate 10 watts? *How much would this reduce L/D? -- Mike Schumann Probably not a great idea. The loss would be equal to the power extracted divided by the efficiency of the turbine and less the form drag of whatever hangs out in the breeze. Better batteries and lower power electronics are the better options - or solar if you can get a clean installation. I do wonder whether the PowerFlarm guys might ever have 1090ES-out in the product roadmap, even as an add-on. That would pretty much settle things once you got to 2020 wouldn't it? 9B |
On Aug 20, 10:20*pm, Andy wrote:
On Aug 20, 8:32*pm, Mike Schumann wrote: On 8/20/2010 2:11 PM, Darryl Ramm wrote: On Aug 20, 8:33 am, Alex *wrote: On Fri, 20 Aug 2010 07:14:01 -0700, Andy wrote: draws 0.8 amps @ 12v I've not been near an airfield for 10 years now, but are there no advances in solar power/battery technology since then that improve a glider's power supply? What is a typical glider's current requirement? -- Alex On Aug 20, 8:33 am, Alex *wrote: On Fri, 20 Aug 2010 07:14:01 -0700, Andy wrote: draws 0.8 amps @ 12v I've not been near an airfield for 10 years now, but are there no advances in solar power/battery technology since then that improve a glider's power supply? What is a typical glider's current requirement? -- Alex With gliders we fly you cannot easily stick solar panels over large areas of the glider because of cost and critical aerodynamic concerns and concerns about solar heating the underlying composite structure. There are specialized solar project exceptions. The manufacturer who dominates solar panels for gliders today is Strobl (http://www.strobl- solar.de ) and their panels are available preinsalled from all leading glider manufacturers or as add-on for a large number of gliders. See my blog athttp://www.darryl-ramm.com/2007/01/strobl-solar-panels-for-sailplanes/ for what a retrofit kit looks like. They typically deliver 15-30 watt maximum for several thousand dollars outlay. The Stobl systems use crystalline wafers in a semi-flexible ETFE (hey that what is used on Trefzel wire, oops another thread...) type plastic encapsulation. Likely all hand-built. The panels are attached with 3M ultra-high-bond double sided tape. Some installations will have molded in recesses for the panels some use hand applied filleting, some wedge trim strips around the panels. The crystalline cells give relatively high efficiency even with only partial fill factor on the panels. Other options emerging might be to use amorphous thin film panels but you are typical starting with low efficiency. I have the larges set of Strobl panels I can get on my ASH-26E engine bay doors that gives a peak spec of 30W (2.5A @ 12V). The actual delivered power is *much* lower. And you should rely not plan on solar panels to significantly boost battery capacity for a single flight as output drops dramatically under cloud streets, overcast sky etc. I really like the Strobl panels but it may be more useful/safer to think of them for use for ground charging of a tied down glider (e.g. some airports have issues with separate panels near the aircraft when tied down) and as a way of stretching capacity over several days when usual ground charging infrastructure is not available. Although it obviously varies widely a typical power consumption number for a glider avionics is roughly around 0.8 amp (as Evan noted his is) for what I am guessing is a typical setup of C302 style computer, a PDA, and VHF radio. Owners should measure and calculate the loads in the glider and estimate the battery capacity needed or run time available from the batteries they have. Do not just divide the nominal "Ah capacity" by amp load, especially at higher loads, you need to use the discharge curves data from a manufacturer to estimate the available run time of a battery at a particular load (most good VRLA batteries are close enough to use another manufacturers spec sheet for a similar sized battery). Transponders (and their encoders) used to be considered a large power hog. And in the days of horse drawn buggies, steam locomotives and traveling wave tube amplifiers etc. they were. While they are much more efficient nowadays, you do need to make sure they fit within a ships power budget. Modern transponders range in power consumption from ~0.5A for a Becker 4401 175W and ACK A30 encoder to around ~0.3A for a Trig TT21 (with built in encoder). Transponder power consumption will vary depending on interrogation rates and temperature (for the encoder heater). i.e. The Trig TT21 uses less power than large PDAs like the iPAQ 4700. The numbers here are realistic for typical glider operations. The NavWorx ADS600-B specs implies it consumes 0.8A at 12V. I have no idea if this is accurate or not, it may be less in practice. Today you need a separate display with third party software to get traffic information/warnings from the device, so guess around 0.45A (e.g. for a iPAQ 4700 PDA dedicated to the UAT data display). Most gliders have some combination of one or more "7Ah" or "12Ah" VRLA batteries. So to give a rough idea of maximum run time from typical single batteries ... (These number are very rough, I don't have my discharge spreadsheet handy that will do this properly, but they give the flavor.) 2.0A load = guess of typical glider load + NavWorx ADS-600B + iPAQ 4700 for UAT traffic display @2.0Ah load a typical "7Ah" VRLA battery ~ 2.7 hours @2.0Ah load a typical "12Ah" VRLA battery ~ 5.2 hours --- Since one scenario is people with Mode C might go UAT vs. buy a new Mode S/1090ES capable transponder. A UAT is does not make a glider visible on TCAS, so if you fly near airliners or fast jets that transponder is a good idea. If you do not then just look at the numbers above) 2.5A load = guess of typical glider load + Becker Mode C + ACK30 + NavWorx ADS600-B + iPAQ 4700 for UAT traffic display @2.5Ah load a typical "7Ah" VRLA battery ~ 2.2 hours @2.5Ah load a typical "12Ah" VRLA battery *~ 4.1 hours --- All these are numbers are for effectively fully discharging the battery, you should really not plan on running down batteries this much on typical flights and having no safety margin. Some fudge (20%) should be deducted from these numbers for typical battery aging. For very cold flights (e.g. wave) then maybe halve these run times. And again do the real calculations for your actual setup. How much battery capacity do you need? My longest flight was 8-9 hours (in my old glider with no solar panel). A typical "serious" XC flight for me is around 5-6 hours. This all assumes the the NavWorx ADS600-B nominal 0.7A spec at 14VDC nominal (i.e. 0.8A at 12VDC) is *correct. It could be lower in practice. I'm not even sure why we are down this rat hole. None of this is not a slight on NavWorx, their UAT transceiver was not designed for the glider market, NavWorx does not claim it is intended for the glider market, or target any marketing to the glider market AFAIK. And issues with incompatibility with all existing (Flarm serial display protocol based) glider traffic display/software, lack of any third party traffic display/warning product tuned for glider specific type environments (esp. gaggles), lack of traffic collision/alert warning from the receiver box etc. are also issues for use in the glider market. I am convinced that a company who wanted to target the USA glider marker with a UAT product would have no deep technical issues addressing these items, or reducing the power consumption significantly today. The issue is justifying a business case for a company to do that for the intersection of the relatively small USA UAT market and the much smaller USA glider market. BTW some older slides and spreadsheets on glider batteries at http://www.darryl-ramm.com/glider-batteries/butI don't think these make much sense unless you've seen me present them. I originally made that presentation because of confusion around batteries and transponders. That confusion went both ways, people way under capacity for their loads (BTW interestingly often with PDAs and ClearNav type devices not just transponders) and people thinking they could never use a transponder, often based on out of date info on transponder power requirements. Darryl Has anyone thought about using a very small ram air turbine to provide power in a glider? *How big would such a turbine have to be to generate 10 watts? *How much would this reduce L/D? -- Mike Schumann Probably not a great idea. The loss would be equal to the power extracted divided by the efficiency of the turbine and less the form drag of whatever hangs out in the breeze. *Better batteries and lower power electronics are the better options - or solar if you can get a clean installation. I do wonder whether the PowerFlarm guys might ever have 1090ES-out in the product roadmap, even as an add-on. That would pretty much settle things once you got to 2020 wouldn't it? 9B A 1090ES data-out only devices as opposed to a full Mode S transponder with 1090ES is in-principle possible but would have - - no visibility to traditional SSR radar (needed now in some places we fly, and in future as a backup for ADS-B) - no visibility to TCAS systems mandated in all large airliners, etc. and widely used in military transport, fast jets etc., existing TCAD/ TAS (active interrogators used in some GA traffic systems) and today's PCAS systems. Aircraft will need to equip with ADS-B-data-in and CDTI (or an certified traffic display) to see a 1090ES-data-out only threat, they will over time but there is requiremnt today for them to do so. Not a requiremnt with airliners etc. like TCAS is, and not a part of the FAA 2020 ADS-B data-out mandate. In Europe (powered) aircraft are widely required to be Mode S equipped, the USA powered aircraft are also required to be transponder equipped in the same areas they will be required to be ADS-B out equipped. ADS-B data-out does not have the compelling GBT interactivity issues it has here in the USA and there is not a wide ADS-B mandate in Europe that will lead lots of GA traffic to want to equip with ADS-B for a while. So the market for 1090ES data-out devices that are not also transponders starts looking smaller and smaller - and products like those from Trig already does Mode S with 1090ES capability for street prices starting at a bit above ~$2,000. By the time you ship an empty box, deal with making it DO260B/1090ES compatible, get that transmitter FCC certified, etc.... I suspect most companies would make the produce a real Mode S transponder with 1090ES capability and be able to sell it to a significantly larger potential market - especially a market that is forced by regulations to deploy that technology (USA ADS-B mandate and Europe Mode S Mandate, etc.). Especially given the actual BOM cost may not be much different, yes a transponder does add a 1030MHz receiver but a lot of the rest of this is software and FPGA firmware. My comments only, I have no insight into any future products from any of these companies. Darryl |
On Aug 22, 11:34*am, Darryl Ramm wrote:
Aircraft will need to equip with ADS-B-data-in and CDTI (or an certified traffic display) to see a 1090ES-data-out only threat... Sigh, I meant to say aircraft will need to equip with ADS-B-data-in and CDTI (or an *un*-certified traffic display) to see a 1090ES-data-out only threat... -- CDTI == cockpit display of traffic information and usually used to mean a certified product meeting RTCA CDTI specs. Hence the correction to my typo above. (and remember here I was discussing the theoretical case of a 1090ES data-out device is *not* also a Mode S transponder) Darryl |
Trig TT21 transponder draws only 125 mA! | Steve Koerner | Soaring | 5 | March 15th 10 09:59 PM |
TRIG TT21 Transponders | Tim Mara[_2_] | Soaring | 12 | September 26th 09 02:01 AM |
Trig TT21 Transponder receives FAA TSO approval | Paul Remde | Soaring | 12 | September 19th 09 02:47 PM |
Trig TT21 in Experimental Aircraft | Paul Remde | Soaring | 5 | July 5th 09 03:15 AM |
Trig TT21 Transponder Thoughts? | jcarlyle | Soaring | 16 | June 23rd 09 04:38 PM |
