Trig TT21 Transponder ... reports?
  #30
Old August 24th 10, 05:04 AM posted to rec.aviation.soaring
Eric Greenwell
Default Trig TT21 Transponder ... reports?
On 8/23/2010 5:38 PM, Tony V wrote:
What I would like is an effective way to measure battery capacity -
that doesn't cost more than the charger.
I like the CBA for discharge tests (westmountainradio.com), but it's
$150 price may be too high if you don't want to be a battery geek. The
Triton2 that SoaringXcellence suggested would do a good job, and it's
only $100 from Tower Hobbies. The Multiplex LN5014 is $75 from Tower,
good if the 0.4 amp discharge rate is OK for you.
The CBA is discharge testing only, but the other two will also
charge/discharge four types of batteries. They are powered from from a
12 volt source, like a battery or an AC input, 12 volt DC output supply.
There may be cheaper discharge testing units, but I don't know of any.
Eric Greenwell - Washington State, USA (netto to net to email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Trig TT21 transponder draws only 125 mA! Steve Koerner Soaring 5 March 15th 10 10:59 PM
TRIG TT21 Transponders Tim Mara[_2_] Soaring 12 September 26th 09 03:01 AM
Trig TT21 Transponder receives FAA TSO approval Paul Remde Soaring 12 September 19th 09 03:47 PM
Trig TT21 in Experimental Aircraft Paul Remde Soaring 5 July 5th 09 04:15 AM
Trig TT21 Transponder Thoughts? jcarlyle Soaring 16 June 23rd 09 05:38 PM
