On Sep 3, 12:42*am, mike malis wrote:
Touche'... FWIW, my comment was meant to be reply to sender. Let's add Voices of Reason to the FAA AD comment page. 186 aircraft, I'll bet at least 5 times that many regular Blanik pilots, and ONLY 20 Comments?! BTW, the SSA says "They can't engineer a solution" on their own, and will need help from the members. *I have joined thier message list, have you? Yesterday I received a call from an AI that runs a soaring operation using an L-13. He said his AD subscription service did not deliver these AD's to him, so I e-mailed him copies and the MB plus some additional information. Fortunately, they hadn't operated his L-13 since the before the 30th, but he missed the original AD also. He's now on the FAA e-mail notification. I've asked the SSA state governors to contact soaring operations in their states with this information. Some number of L-13's are privately owned and operated including one operation in my state that isn't SSA affiliated. I'm still not confident that all L-13 owner/operators are aware of the latest AD. Especially since pros and club volunteers have been found unaware as late as yesterday. Indeed, if you are not logged into the SSA web site, the link does not work, nor do the news items appear on the home page because they are on the member side of the server. The SSA is a voluntary non-profit organization. We do not have a 'technical committee' as the BGA once did/does. The BGA technical committee could authorize modifications to a point and worked with manufacturers directly. The FAA controls that aspect here and plays by a different set of rules. If someone is putting together a list of owners and airframes, I'll help. If not, I'll get started. Based on the aircraft codes, there are 211 on the US registry. I suspect a fair number are hulks, but even if 80-90 are still flying, that's significant, and I know of at least one that was just about to return to service after a wing splice. Frank Whiteley |
Clearly we need to band together in the US and abroad on this issue
since we are likely all to be held to some sort of manufacturer approved inspection process. In the US, it would be nice to have an SSA representative on top of this, working with the FAA, working with LET, coordinating the development of an inspection. I know that our club maintenance officer has been on the phone regularly with the FAA. I'm sure that this is happening time and again from other operators. I've requested to be added to the SSA list and made the suggestion that in addition to coordinating the test development effort, the SSA could act as an escrow holder for funds to pay for the test development. $100 or $200 per owner would raise $10,000 or more without causing any of us individually too much wallet pain. That should be a large enough sum of money to cover the development of a test that we all could benefit from and enough money to make it attractive to an engineer/testing firm. It won't resolve getting approval from LET or the fact that the approved test may be expensive or possibly requiring equipment that is not readily available to many AI's or operators. We've got to start somewhere. On Sep 3, 11:14*am, Frank Whiteley wrote: On Sep 3, 12:42*am, mike malis wrote: Touche'... FWIW, my comment was meant to be reply to sender. Let's add Voices of Reason to the FAA AD comment page. 186 aircraft, I'll bet at least 5 times that many regular Blanik pilots, and ONLY 20 Comments?! BTW, the SSA says "They can't engineer a solution" on their own, and will need help from the members. *I have joined thier message list, have you? Yesterday I received a call from an AI that runs a soaring operation using an L-13. *He said his AD subscription service did not deliver these AD's to him, so I e-mailed him copies and the MB plus some additional information. *Fortunately, they hadn't operated his L-13 since the before the 30th, but he missed the original AD also. *He's now on the FAA e-mail notification. I've asked the SSA state governors to contact soaring operations in their states with this information. Some number of L-13's are privately owned and operated including one operation in my state that isn't SSA affiliated. *I'm still not confident that all L-13 owner/operators are aware of the latest AD. Especially since pros and club volunteers have been found unaware as late as yesterday. Indeed, if you are not logged into the SSA web site, the link does not work, nor do the news items appear on the home page because they are on the member side of the server. The SSA is a voluntary non-profit organization. *We do not have a 'technical committee' as the BGA once did/does. *The BGA *technical committee could authorize modifications to a point and worked with manufacturers directly. *The FAA controls that aspect here and plays by a different set of rules. If someone is putting together a list of owners and airframes, I'll help. *If not, I'll get started. *Based on the aircraft codes, there are 211 on the US registry. *I suspect a fair number are hulks, but even if 80-90 are still flying, that's significant, and I know of at least one that was just about to return to service after a wing splice. Frank Whiteley |
On Sep 3, 1:22*pm, Morgan wrote:
Clearly we need to band together in the US and abroad on this issue since we are likely all to be held to some sort of manufacturer approved inspection process. *In the US, it would be nice to have an SSA representative on top of this, working with the FAA, working with LET, coordinating the development of an inspection. *I know that our club maintenance officer has been on the phone regularly with the FAA. *I'm sure that this is happening time and again from other operators. I've requested to be added to the SSA list and made the suggestion that in addition to coordinating the test development effort, the SSA could act as an escrow holder for funds to pay for the test development. *$100 or $200 per owner would raise $10,000 or more without causing any of us individually too much wallet pain. *That should be a large enough sum of money to cover the development of a test that we all could benefit from and enough money to make it attractive to an engineer/testing firm. It won't resolve getting approval from LET or the fact that the approved test may be expensive or possibly requiring equipment that is not readily available to many AI's or operators. *We've got to start somewhere. On Sep 3, 11:14*am, Frank Whiteley wrote: On Sep 3, 12:42*am, mike malis wrote: Touche'... FWIW, my comment was meant to be reply to sender. Let's add Voices of Reason to the FAA AD comment page. 186 aircraft, I'll bet at least 5 times that many regular Blanik pilots, and ONLY 20 Comments?! BTW, the SSA says "They can't engineer a solution" on their own, and will need help from the members. *I have joined thier message list, have you? Yesterday I received a call from an AI that runs a soaring operation using an L-13. *He said his AD subscription service did not deliver these AD's to him, so I e-mailed him copies and the MB plus some additional information. *Fortunately, they hadn't operated his L-13 since the before the 30th, but he missed the original AD also. *He's now on the FAA e-mail notification. I've asked the SSA state governors to contact soaring operations in their states with this information. Some number of L-13's are privately owned and operated including one operation in my state that isn't SSA affiliated. *I'm still not confident that all L-13 owner/operators are aware of the latest AD. Especially since pros and club volunteers have been found unaware as late as yesterday. Indeed, if you are not logged into the SSA web site, the link does not work, nor do the news items appear on the home page because they are on the member side of the server. The SSA is a voluntary non-profit organization. *We do not have a 'technical committee' as the BGA once did/does. *The BGA *technical committee could authorize modifications to a point and worked with manufacturers directly. *The FAA controls that aspect here and plays by a different set of rules. If someone is putting together a list of owners and airframes, I'll help. *If not, I'll get started. *Based on the aircraft codes, there are 211 on the US registry. *I suspect a fair number are hulks, but even if 80-90 are still flying, that's significant, and I know of at least one that was just about to return to service after a wing splice. Frank Whiteley Yes. I searching the aircraft codes for the L-13 I get 05614SN 7 1360305 5 1360306 183 1360312 15 L13 AC 1360315 1 That's a total of 211 on the US registry of all marks. A few are experimental, some are USAFA, a couple may be coded incorrectly, listed as L13 AC but manufactured over 20 years before the L-13 AC was an option. Even if only 80-90 are actually flying, it's still quite significant. The grunt work is putting the N-numbers/serial numbers including splices together with current contacts and those contacts maybe providing their AI and DER contacts, as applicable. That will take a week or two, but may reduce the number of folks working at cross purposes. Frank Whiteley |
EASA has just issued the 4th AD for Blanik L-13's, issued 3 SEP,
effective 5 SEP 2010: http://ad.easa.europa.eu/ad/2010-0185-E This supercedes the previous 3 AD's on the L-13 spar inspection. Expect FAA will issue yet another AD soon. Burt (currently near Munich) |
On Sep 3, 1:36*pm, Frank Whiteley wrote:
On Sep 3, 1:22*pm, Morgan wrote: Clearly we need to band together in the US and abroad on this issue since we are likely all to be held to some sort of manufacturer approved inspection process. *In the US, it would be nice to have an SSA representative on top of this, working with the FAA, working with LET, coordinating the development of an inspection. *I know that our club maintenance officer has been on the phone regularly with the FAA. *I'm sure that this is happening time and again from other operators. I've requested to be added to the SSA list and made the suggestion that in addition to coordinating the test development effort, the SSA could act as an escrow holder for funds to pay for the test development. *$100 or $200 per owner would raise $10,000 or more without causing any of us individually too much wallet pain. *That should be a large enough sum of money to cover the development of a test that we all could benefit from and enough money to make it attractive to an engineer/testing firm. It won't resolve getting approval from LET or the fact that the approved test may be expensive or possibly requiring equipment that is not readily available to many AI's or operators. *We've got to start somewhere. On Sep 3, 11:14*am, Frank Whiteley wrote: On Sep 3, 12:42*am, mike malis wrote: Touche'... FWIW, my comment was meant to be reply to sender. Let's add Voices of Reason to the FAA AD comment page. 186 aircraft, I'll bet at least 5 times that many regular Blanik pilots, and ONLY 20 Comments?! BTW, the SSA says "They can't engineer a solution" on their own, and will need help from the members. *I have joined thier message list, have you? Yesterday I received a call from an AI that runs a soaring operation using an L-13. *He said his AD subscription service did not deliver these AD's to him, so I e-mailed him copies and the MB plus some additional information. *Fortunately, they hadn't operated his L-13 since the before the 30th, but he missed the original AD also. *He's now on the FAA e-mail notification. I've asked the SSA state governors to contact soaring operations in their states with this information. Some number of L-13's are privately owned and operated including one operation in my state that isn't SSA affiliated. *I'm still not confident that all L-13 owner/operators are aware of the latest AD. Especially since pros and club volunteers have been found unaware as late as yesterday. Indeed, if you are not logged into the SSA web site, the link does not work, nor do the news items appear on the home page because they are on the member side of the server. The SSA is a voluntary non-profit organization. *We do not have a 'technical committee' as the BGA once did/does. *The BGA *technical committee could authorize modifications to a point and worked with manufacturers directly. *The FAA controls that aspect here and plays by a different set of rules. If someone is putting together a list of owners and airframes, I'll help. *If not, I'll get started. *Based on the aircraft codes, there are 211 on the US registry. *I suspect a fair number are hulks, but even if 80-90 are still flying, that's significant, and I know of at least one that was just about to return to service after a wing splice. Frank Whiteley Yes. I searching the aircraft codes for the L-13 *I get 05614SN 7 1360305 5 1360306 183 1360312 15 L13 AC 1360315 *1 That's a total of 211 on the US registry of all marks. *A few are experimental, some are USAFA, a couple may be coded incorrectly, listed as L13 AC but manufactured over 20 years before the L-13 AC was an option. Even if only 80-90 are actually flying, it's still quite significant. The grunt work is putting the N-numbers/serial numbers including splices together with current contacts and those contacts maybe providing their AI and DER contacts, as applicable. *That will take a week or two, but may reduce the number of folks working at cross purposes. Frank Whiteley I'm about 1/3 of the way with reconciling L-13 registrations with contact information then the NTSB database. Not surprisingly a few are indeterminate, so will turn to the wider soaring community with those in a couple of days. Results will go to the google site and will be updated as information is received. Frank |
Blanik L-23 Super Blanik Manual -F.C.F.S. | Joel Flamenbaum | Soaring | 2 | April 14th 10 03:29 PM |
Grounding of control tubes/cables | jcarlyle | Soaring | 19 | March 7th 08 07:30 PM |
9-11 Response, was F-15 grounding | [email protected] | Piloting | 19 | January 4th 08 04:54 AM |
Magneto grounding Question | Doug Palmer | Home Built | 3 | October 8th 05 01:10 AM |
Grounding of K-7 and K-10s in the UK. | Robertmudd1u | Soaring | 1 | May 28th 04 02:53 AM |
