US SSA Contest Pilot Opinion Poll
Old September 21st 10, 06:21 PM posted to rec.aviation.soaring
John Cochrane[_2_]
Default US SSA Contest Pilot Opinion Poll
On Sep 21, 10:56*am, "noel.wade" wrote:
Thanks, Ken! *Lots
Wow, the TAT/MAT proposal is a tough one! *
Well, you can probably guess who came up with that one! I did my best
to write a poll question that explained the issue sufficiently, but
yet was somewhere near short enough to put on the poll. I'm happy to
answer questions directly or via r.a.s. I know it's a complex issue,
but if we do what is, I think, the right answer, we need to all
understand that means a 60 mile, one hour "finish" might score less
than a 250 mile landout.
It does apply mostly to MAT, but can apply to turn area tasks. Some
CDs love 30 mile circles, so it is possible to nick the circles, fly
60 miles and "finish" in one hour, while the "real" task flies 250
miles in 3.5 hours. Current rules guarantee you 600 points (i.e. give
you the same as the winner's distance points) for this little gambit;
the proposal will not. That's especially a problem in sports class;
the circles have to be set large enough so a short course is available
for the 1-26; but then the nimbus 4 gets the "nick the circle and
finish" option.
John Cochrane
Old September 23rd 10, 03:48 AM posted to rec.aviation.soaring
Frank[_12_]
On Sep 21, 1:21*pm, John Cochrane
Thanks, Ken! *Lots
answer questions directly or via r.a.s. *I know it's a complex issue,
It does apply mostly to MAT, *but can apply to turn area tasks. Some
the proposal will not. *That's especially a problem in sports class;
finish" option.
John Cochrane
Hmm, is this an unintended side-effect of an earlier rule change to
give long landouts more points (from 400 to 600 IIRC)? Before that
change, scores for finishers were spread over 600 pts. The larger
spread meant that a 'short finisher' was more heavily punished,
relative to the day winner.
If the two rule changes are viewed together, they represent a very
significant change away from the philosophy that it is more important
to finish than it is to rack up distance.
I'm not sure that's all bad, but it is a significant change
TA
Old September 23rd 10, 04:21 AM posted to rec.aviation.soaring
John Cochrane[_2_]
give long landouts more points (from 400 to 600 IIRC)? *Before that
change, scores for finishers were spread over 600 pts. *The larger
TA
A little bit, but really it is more an unintended effect of applying
assigned task rules to MAT and TAT. In an assigned task, if you
"finish" you made it all the way around the course, so it makes sense
to give everyone who does that the same distance points. In the TAT
and MAT, there is the option to "finish" by flying 61 miles, when
everybody else goes 250. On an assigned task, this would be counted as
"landing at an airport near the first turn" and get very few points.
On TAT and MAT, you get to call that a "finish" and get the same
distance points as everyone else who went 250 miles. Whether that's
400 or 600 points is a bit of a difference, but minor. We would still
be giving everyone who went from 60 to 249 miles the same distance
points.
So it's really about what do we think of as "finishing the task" when
everybody goes different distances.
John Cochrane
Old September 23rd 10, 03:26 PM posted to rec.aviation.soaring
Frank[_12_]
On Sep 22, 11:21*pm, John Cochrane
TA
be giving everyone who went from 60 to *249 miles the same distance
points.
John Cochrane
Hmm, good point about the meaning of 'finisher'. I can see this
change also increasing the motivation to avoid coming home early, even
at the cost of a significantly higher chance of landing out.
Right now, coming home early is much more preferable to landing out,
so the decision to turn back in the face of deteriorating weather is
usually a no-brainer. However, if turning back and taking a
significantly under-time finish is going to put your score among the
landouts anyway, why not continue and see what happens - maybe I'll
make it through that man-eating thunderstorm over unlandable terrain
after all? ;-).
Do we, as an organization, really want to be biasing the 'Sporting
Risk' equation in that direction?
TA
Old September 23rd 10, 05:29 PM posted to rec.aviation.soaring
noel.wade
TA
Exactly my concern with this rule, too.
I understand your arguments, John; they make a fair amount of
sense... I don't want to reward someone who "took it easy" because
their glider has long legs. But a big part of me also thinks its just
weird to reward someone who didn't make it around the course! Even
though ATs, TATs, and MATs are all very different, they start with the
core idea that you have a start, some waypoints, and a finish. And
the overriding theme is to make it around the course and to the
finish. Screwing up that fundamental "getting to the finish" part can
be interpreted as a bad performance and/or bad decision-making. I
don't want to reward that, simply because the pilot has big cojones
and is willing to fly into a bad situation on the gamble that he or
she will rack up more distance points than others before hitting the
dirt. And when does one "flip the switch" mentally, to go for that
instead of speed points? Would it be on the worst of days, when
everyone's cutting the task really short (isn't this when we usually
see MATs called most-often, too)? That's when we want to encourage
people to strike out on their own? hrrm...
Also: What other sport defines a course and a finish, but gives some
people more credit if they DON'T cross the finish-line?
Like I said befo It seems to me that we're turning the system on
its ear. We're moving away from "the course" as the underlying
foundation, and moving towards "speed and distance are more important
than the course"; which is a big shift IMHO.
I'm not vehemently opposed to this, but I still am not comfortable
with it. In some ways, it seems like a fix primarily for the Sports
Class, since the "1-26 vs Nimbus4" argument only applies there.
Performance levels are so much closer in the FAI classes, you're
"fixing" anything (no one can use min-distance to gain a big advantage
over others). In the FAI classes, the way I see it, you're flat-out
shifting the focus of the TAT & MAT away from "fly the course and
return at minimum time, go for max speed". You're moving the focus
towards "make nominal (or greater) distance in a reasonable time
without sacrificing much speed and if it starts to go bad screw
getting home and make max distance you can".
I see the "problem" with the current system; but if you view
competition tasks through the lens of "complete the course, first and
foremost" then its only a problem for the Sports Class with its wide
performance-level variance. For the other classes its more about how
you want to view tasks and what should be the _most-important_
criteria for judging someone's performance. Is it speed around the
course and across the finish line? Or is it distance?
--Noel
P.S. BTW, since other threads on RAS are talking about the Worlds -
just out of curiosity do any other countries (or the IGC) have scoring
rules like this, wherein non-finishers can score higher than
finishers?
Old September 24th 10, 12:48 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
In the olden days, when we had waypoints that were actually points, we
had a well defined course, and it was reasonable to talk about
completing it. Now we no longer have points, but huge areas, and you can
draw millions of courses, so maybe we should drop the idea of "the
course" and just talk about the Task. That's what people are trying to
complete - "the course" no longer exists, as each pilot picks his own
course.
And while that is the backbone of the Sports Class, it is also the
reason I had little interest in it, and eventually stopped racing as the
other classes flew fewer and fewer assigned speed tasks. But I digress...
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm http://tinyurl.com/yb3xywl
- "A Guide to Self-launching Sailplane Operation Mar/2004" Much of what you need to know tinyurl.com/yfs7tnz
Old September 24th 10, 03:34 PM posted to rec.aviation.soaring
John Cochrane[_2_]
performance-level variance. *For the other classes its more about how
criteria for judging someone's performance. *Is it speed around the
course and across the finish line? *Or is it distance?
course.
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarmhttp://tinyurl.com/yb3xywl
My view is quite similar to Eric's. Back in the AST days, there was a
"course" and if you made it home you "finished". I'm not so sure that
doing 61 miles and beetling home on a 270 mile day qualifies in the
same way. It's as if we let people turn around at the first turn and
get a "finish" anyway. That is the central philosophical issue.
It does happen in TATs, and in FAI classes too. The examples on the
poll question were from FAI classes. Newcastle day 2 just had a TAT
with possible distances from 66 o 245 miles, in view of very uncertain
weather.
I'm as concerned about safety and incentives not to push on in bad
weather as the next guy, and I'm usually on the other end of those
discussions. However, we have an airport bonus for that. It's not
obvious to me that we should give 600 points for landing at one
particular airport and 25 points for landing at another one. If one
sees a problem in people pushing on in bad weather, raising the
airport bonus is a more sensible step.
Part of my preference is because the change removes and awful roll-
the-dice decision, stop in an hour for a "finish" or push on for speed
points. I hate big roll of the dice decisions. In the AST, on which
the scoring equation was based, there was no such decision, you just
keep plugging along as long as you can. The proposed new system
removes a lot of that agonizing. It's especially bad in the TAT
because you have to commit early if you want to use the option to nick
the cylinders and finish in one hour. I also dislike MATs where the
right strategy is always to buzz around in gliding distance of the
home airport so you make sure to get those "finisher" points. I didn't
take two weeks off of work and drive a thousand miles for that. Stay
safe, yes. Stay near airports, sure. But not necessarily right near
the home airport.
John Cochrane
SSA Contest Rules Committee Election and Poll Results (USA) Ken Sorenson Soaring 1 October 14th 08 02:11 AM
US SSA/SRA Contest Rules Poll Ken Sorenson Soaring 18 November 4th 07 05:59 PM
USA - 2005 SRA Pilot Opinion Poll Results Posted Ken Kochanski (KK) Soaring 0 December 1st 05 12:33 PM
2005 SSA Contest Rules Poll and Election [email protected] Soaring 0 September 27th 05 01:47 PM
500 foot rule and pilot opinion poll John Cochrane Soaring 84 October 2nd 03 02:13 PM
