On Tue, 19 Oct 2010 06:48:32 -0700, Tony wrote:
I'm having trouble visualizing what you typed. Perhaps its just too early. The fuselage is ~20-22 ft long. Each wing is about 18 or 19 ft long. Tony, On those measurements what I was thinking wouldn't work. I thought your fuselage was quite a bit shorter than the wings, which isn't the case. I have a box trailer for my Libelle with the wings taking up the full trailer length except for about a foot at the rear. The fuselage is in the back of the trailer with the rear of the rudder just inside the door. Each wing is 8m long including spar stubs, while the fuselage is only 6.2m, so I've got around 2m (6'6") going begging in front of the fuselage where my tow-out gear, trestles and spare wheel live. And there is still a lot of spare cubic in there. I've got a friend with a Duster and because of its massive fixed center section the solution for his trailer was to lay the wings flat on the floor. I'm wondering if maybe a good solution for the double Cherokee trailer would be two racks for the 4 wings on the floor. one wing would go root first the other tip first. then the fuselages in, one nose first the other tail first. I see what you're saying, which would leave a parallel-sides space between the wing racks. The thing I wondered about is how far apart would the fuselages have to be so the wing stubs on the rear-facing one would pass the fin of the forward facing one when you were getting it out. Same problem applies to the other end and other stubs and fin of course. Being a model builder, I'd probably make reasonably accurate models of the wings, tails and fuselages out of, say, white foam, so you could experiment with balsa sticks to make supports and see not only how the fit them close together but if you can still get them in and out. I have a feeling that might be the hardest part. FWIW my trailer seems to have been designed by packing the Libelle bits into the smallest possible arrangement and then leaving 3 inches all round. It goes into and comes out of the trailer OK but care is needed. Its very tight inside there and I'm bent double moving the wings, which fit tip-forward, between their root spar supports and a dolly. This operation would be pretty much impossible without a thick plastic pad to rest the root leading edge on while getting inside to lift the spars onto or off their tiedown rack. The moral of this is, if you're building an end-loading box trailer, be sure to leave more than the absolute minimum of free space or you'll curse yourself in future. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Here is a strange idea.
Picture a basic flatbed trailer. Add the left and right walls, hinged at the bottom and outside of the floor to fold from the normal up and down position to horizontal and beside the floor. Drive a fuselage onto each side, secure them in jigs, winch the sides back to up and down like normal. Wings secured in jigs between them. Front and back and top stationary with smaller access doors. -- Jim in NC |
ASK 21 in Cobra trailer single or double axle? | Karaka | Soaring | 7 | June 19th 09 10:15 PM |
Trailer tires for old (1981) Komet Trailer | [email protected] | Soaring | 3 | May 13th 09 10:24 PM |
Double scissor jack for trailer ramp? | Bullwinkle | Soaring | 15 | January 18th 06 05:18 PM |
Five Foot Wide Glider Trailer | Steve Leonard | Soaring | 2 | December 8th 05 03:35 AM |
Five-foot-wide glider trailer? | Bob Kuykendall | Soaring | 1 | December 6th 05 10:45 PM |
