Where do main pin holes come from?
Old November 2nd 10, 02:43 PM posted to rec.aviation.soaring
Bob Kuykendall
Default Where do main pin holes come from?
On Nov 2, 6:33*am, JJ Sinclair wrote:
*...Looking good Bob, did you glue in an uncut bushing and then cut the
wings apart after the epoxy set?
Thanks, JJ!
No, we inserted our bushings in pairs with the separation lines
between the spars. It did get a bit of epoxy between the pin and the
bushing, and the first removal was a bit hard. But after cleaning the
pins and bushings with acetone and re-lubing them, the pins slid
straight in.
Bob K.
Mystery holes. Monk Piloting 16 January 2nd 09 04:43 AM
Covering holes [email protected] Soaring 9 May 2nd 08 05:57 PM
Tube Fuse Oil Holes John[_17_] Home Built 8 March 21st 08 12:11 PM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
Filling Holes AKperson Owning 1 July 20th 05 03:54 PM
