Cutting 57mm holes in the instrument panel.....how to?
Old November 12th 10, 07:20 AM posted to rec.aviation.soaring
Craig[_2_]
Default Cutting 57mm holes in the instrument panel.....how to?
On Nov 11, 9:42*pm, Bob Kuykendall wrote:
On Nov 11, 9:39*pm, Alia Kuykendall
Sawzall.
Much neater than the chainsaw, but not as cool as a loop of det cord.
Thanks, Bob K.
Oops, that was my post.
Thanks, Bob K.
We just figured your daughter was picking up the torch. Put a sawzall
in their hands when they're three and they'll never look back.
Craig
Old November 12th 10, 08:43 AM posted to rec.aviation.soaring
Peter Purdie[_3_]
The suggestion to use 2-1/4" or 3-1/8" hole saws is absolutely correct.
Those were the original standard instrument sizes (and you will find that
the P.C.D. of the fixing holes is also a neat measurement in inches.
Over here in metricland where they don't understand inches, it was
converted to the nearest integer millimetre.
And a hole saw (used on a panel clamped down to a good rigid drill press
bed for accuracy) is a damn sight less costly than a hole punch.
Although Bob's idea of a piece of det cord looks interesting, I must try
it. On someone else's panel...............
Old November 12th 10, 11:09 AM posted to rec.aviation.soaring
Derek C
it. *On someone else's panel...............
Surely you can order metric hole saws by the internet? The hard work
way of doing it is to scribe the correct size hole onto the panel,
drill out a series of adjacent holes just inside the scribe mark,
knock out the centre, and them finish to size with a half round file.
Derek C
WANTED: 57MM Avionic / Instrument - Stuff Scott Alexander[_2_] Soaring 1 October 25th 09 03:56 AM
WANTED: 57MM Avionic / Instrument - Stuff Scott Alexander[_2_] Soaring 0 October 25th 09 01:58 AM
DG-300 instrument panel [email protected] Soaring 14 January 29th 06 02:48 PM
LS 6 b instrument panel John Brenann Soaring 4 November 19th 05 04:37 AM
When Poorboys drill holes ...was: Drilling holes in steel tubing wright1902glider Home Built 4 November 4th 05 01:19 AM
