On 11-21-2010 16:42, sisu1a wrote:
I don't recall a 337 as changing them to experimental... 337 has nothing to do with EXP/Std reg changeover. It is the number of the form that stands for "major repair or alteration" and is typically accompanied by a new weight and balance when major repairs (reattaching a tailboom for instance) or alterations (like winglets), although may not be necessarily in every case. My SZD59 is EXP reg, but I still went the 337 route when I modded my stock mechanical brakes to a hydraulic Cleveland setup. Didn't need the w&b for this job, since the part total was within 1.5lbs of the old setup and that is all predominantly on CofG, but I didn't trust my old one and wanted to put some weight in the tail, so a fresh w&b was useful to me to determine how much... And why exactly do you want to keep the std reg? Do you use it in a commercial capacity? (obviously not since it has 1 seat...) Exp rating allows you a lot more leeway with *legally getting your ship/cockpit dialed in etc. Work that falls somewhere between changing a tire and needing a 337 still needs to be signed off by an A&P, but a 337 needs an A&I and is much more involved. Std means anything beyond changing a tire/simple maintenance level work has to be farmed out to an A&P, regardless of your skills. -Paul Actually, I am not the one who started the thread about going into the experimental category. The reason "I" would stay in the standard category is to avoid any restrictions that may come with the experimental category, such as for exhibition only, etc. I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. Also, going to an experimental certificate won't eliminate the need for A&P inspections/sign offs. As far as I know, only people with repairman certificates can sign off work on an experimental "AMATEUR BUILT" aircraft and then only if they built a majority of the aircraft. Just putting winglets on a certified bird would not be a basis to get a repairman's certificate... |
On Nov 21, 10:12*am, Scott wrote:
On 11-21-2010 16:42, sisu1a wrote: * *I don't recall a 337 as changing them to experimental... 337 has nothing to do with EXP/Std reg changeover. It is the number of the form that stands for "major repair or alteration" and is typically accompanied by a new weight and balance when major repairs (reattaching a tailboom for instance) or alterations (like winglets), although may not be necessarily in every case. My SZD59 is EXP reg, but I still went the 337 route when I modded my stock mechanical brakes to a hydraulic Cleveland setup. Didn't need the w&b for this job, since the part total was within 1.5lbs of the old setup and that is all predominantly on CofG, but I didn't trust my old one and wanted to put some weight in the tail, so a fresh w&b was useful to me to determine how much... And why exactly do you want to keep the std reg? Do you use it in a commercial capacity? (obviously not since it has 1 seat...) Exp rating allows you a lot more leeway with *legally getting your ship/cockpit dialed in etc. Work that falls somewhere between changing a tire and needing a 337 still needs to be signed off by an A&P, but a 337 needs an A&I and is much more involved. Std means anything beyond changing a tire/simple maintenance level work has to be farmed out to an A&P, regardless of your skills. -Paul Actually, I am not the one who started the thread about going into the experimental category. *The reason "I" would stay in the standard category is to avoid any restrictions that may come with the experimental category, such as for exhibition only, etc. *I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. *Also, going to an experimental certificate won't eliminate the need for A&P inspections/sign offs. *As far as I know, only people with repairman certificates can sign off work on an experimental "AMATEUR BUILT" aircraft and then only if they built a majority of the aircraft. *Just putting winglets on a certified bird would not be a basis to get a repairman's certificate...- Hide quoted text - - Show quoted text - Scott, Any A&P can annual an Experimental or Experimental Exhibition aircraft. This is a lot easier formany people. Dan WO |
I'm pretty sure going to experimental would place various restrictions on the flying of the aircraft. Â*
I really like to fiddle my own panel/Oâ‚‚/cockpit as I see fit, without paying someone $100+ an hour to do it for me, usually not to my liking (no mechanic cares as much about my glider as I do ![]() being able to do other repair work on it myself, of course following the FAR guidelines on work/inspection/signoffs. There are no *practical restrictions on your flight regime in an EXP glider though. Besides not being able to use it commercially (renting it out, not an issue for your Cirrus ) and a little extra paperwork, the only limitation I can think of would be including the term 'experimental' in your identification stream when announcing yourself to ATC if you ever need to. I had an EXP glider I thought I wanted to be Std when I first got it. After looking at what the actual differences are (not the perceived ones...), I realized I don't want a Std reg glider for myself anyhow. Seeing you are up for making your own winglets, to me it's strange you would lean towards Std since it keeps your obviously skilled hands tied behind your back... -Paul |
FAA Revoking Standard Airworthiness Certificate DG-505 | NG | Soaring | 32 | February 16th 17 02:23 PM |
Airworthiness Certificate Replacement? | [email protected] | Soaring | 6 | June 26th 08 07:11 PM |
USA Glider Experimental Airworthiness Certificate | charlie foxtrot | Soaring | 4 | April 15th 06 05:04 AM |
Exhibition/Racing Airworthiness Certificate Question | bsquared | Soaring | 5 | June 22nd 04 06:24 PM |
Airworthiness Directives for Jantar Standard 3 | Miguel Lavalle | Soaring | 5 | January 24th 04 10:55 AM |
