How do I legallly install winglets on a standard airworthiness certificate?
Old November 22nd 10, 02:21 PM posted to rec.aviation.soaring
Guy Byars[_2_]
Default How do I legallly install winglets on a standard airworthiness certificate?
And why exactly do you want to keep the std reg?
Some insurance policies take a very dim view of EXPERIMENTAL
aircraft. I recall one policy that would actually cover me if flying
an aircraft with a STD airworthiness certificate, but not when flying
an aircraft with an EXPERIMENTAL airworthiness certificate. This
might be an issue for some.
Old November 22nd 10, 03:07 PM posted to rec.aviation.soaring
Tony[_5_]
aircraft. *I recall one policy that would actually cover me if flying
an aircraft with an EXPERIMENTAL airworthiness certificate. *This
absolutely positively not the case for the SSA Group plan through
Costello. Also if the group plan won't work for you the EAA has a
fine group insurance plan as well.
Old November 22nd 10, 05:51 PM posted to rec.aviation.soaring
Andy[_1_]
Costello. *Also if the group plan won't work for you the EAA has a
The insurance issue for experimental relates to Life insurance not to
the aircraft hull and liability insurance.
Andy
Old November 22nd 10, 07:39 PM posted to rec.aviation.soaring
Frank Whiteley
I think he was talking of life insurance underwriters. Some will not
cover you, others want a rider if you fly personally, perhaps another
if you fly experimental. Some are not so restrictive. NY Life was
one several years ago. No idea of the current status. AOPA has
programs for pilots.
Frank Whiteley
Old November 22nd 10, 09:50 PM posted to rec.aviation.soaring
vaughn[_3_]
"Frank Whiteley" wrote in message
As do these folks: http://www.piclife.com/ Two years ago I priced several
companies, including AOPA. PICLife (they are actually just an agency, like
Costello) came in with the best price. Your results may vary. Life insurance
is a significant investment, get multiple quotes!
Vaughn
FAA Revoking Standard Airworthiness Certificate DG-505 NG Soaring 32 February 16th 17 02:23 PM
Airworthiness Certificate Replacement? [email protected] Soaring 6 June 26th 08 07:11 PM
USA Glider Experimental Airworthiness Certificate charlie foxtrot Soaring 4 April 15th 06 05:04 AM
Exhibition/Racing Airworthiness Certificate Question bsquared Soaring 5 June 22nd 04 06:24 PM
Airworthiness Directives for Jantar Standard 3 Miguel Lavalle Soaring 5 January 24th 04 10:55 AM
