On Feb 3, 12:02*pm, a wrote:
Gotta check pretty often, have had vac pump failures in actual IMC -- don't want to chase a spinning down gyro It may be just bad luck, I doubt I spend 25% of the time in actual IMCs, but have had two vac pump and one alternator failure in actual (but soft IFR approaches) IMC I've had one fail in IMC, but it wasn't the pump, but the vacuum pump regulator that failed in IMC in my prior Sundowner. Caused my AI to display an extreme pitch up on a climb because it was pegged opposite of failure. My ASI idicated a steady 90 knots with a steady RPM so I knew something was wrong with AI right away. I advised ATC that I was going to use GPS ground track for headings. I then reverted to my partial panel skills ignoring vacuum system instrumentation. Turned out DG wasn't affected but I wasn't leaving anything to trust it. On VFR flights other then checking the DG accuracy when I lined up on the runway, until now, I never crossed checked it at the end of the turn as I had assumed it worked if it worked on the ground (runup normally would catch this as well as last minute check on runway before blast off). As you can see what assume does. DG was iffy in performance (digressing by 10 degrees) but didn't misbehave that much on my turns. I tend to be more lax on instrument scans (CROSS CHECKING) on VFR flights only because my eyes need to be outside the window! So even if this happened tomorrow, realistically I don't think I would have caught this mistake. |
![]() I tend to be more lax on instrument scans (CROSS CHECKING) on VFR flights only because my eyes need to be outside the window! *So even if this happened tomorrow, realistically I don't think I would have caught this mistake. I think being near line of sight while looking forward is exactly why the compass is in on top of the panel in sight of the windshield... I've yet to fly a plane where it's not there... Cheers |
"Flaps_50!" wrote:
I think being near line of sight while looking forward is exactly why the compass is in on top of the panel in sight of the windshield... I've yet to fly a plane where it's not there... I believe it's up on the glareshield to minimize magnetic interference from the other instruments and the aircraft structure. Mike |
On Feb 4, 5:23*am, "Flaps_50!" wrote:
I've yet to fly a plane where it's not there... Then you never been in my Sundowner as it was NOT on top of the panel..... |
On Feb 5, 8:32*am, " wrote:
On Feb 4, 5:23*am, "Flaps_50!" wrote: I've yet to fly a plane where it's not there... Then you never been in my Sundowner as it was NOT on top of the panel..... Where is it in a sundowner? But it was there in the 172 you flew? |
On Feb 5, 3:53*am, "Flaps_50!" wrote:
On Feb 5, 8:32*am, " wrote: On Feb 4, 5:23*am, "Flaps_50!" wrote: I've yet to fly a plane where it's not there... Then you never been in my Sundowner as it was NOT on top of the panel..... Where is it in a sundowner? But it was there in *the 172 you flew? It was a vertical card compass that hung from the top of the wind screen. Yes it was on the panel of the Cessna. |
REC: Jeppesen commercial pilot videos PLEASE!!! | koos | Piloting | 1 | April 27th 07 01:34 PM |
Pilot controlled lighting controller | DL | Owning | 3 | February 20th 07 07:55 PM |
Pilot controlled lighting controller | DL | Home Built | 3 | February 20th 07 07:55 PM |
Online WW2 Videos: Pilot Training, plus A-36 dive bombing, Black Cat PBY- | Zeno | Piloting | 0 | June 5th 06 06:37 PM |
Pilot nearly crashes in IMC, Controller helps | pimenthal | Piloting | 32 | September 27th 05 01:06 PM |
