Transponder antenna installations
Old February 6th 11, 04:49 PM posted to rec.aviation.soaring
soaringpilot[_3_]
Default Transponder antenna installations
First of all: what kind of a glider are you installing the antenna in?
If it is carbon with enough conductivity in the fuselage then you have
to go outside, but if not, you can install the antena inside.
Installing antenna on top of the panel cover was probably a bad place,
but primarily because with proper ground plane primary emission would
be up, rather than down towards radar station.
Cheers,
Henryk
On Feb 5, 7:26*pm, Dick wrote:
I am installing a new vane style antenna for my transponder. *My
original antenna was located where the cg hook used to be on my
discus. *This location often tangled with the trailer ramp when
loading the glider. *Next I tried a whip style on top of my instrument
panel cover. *All of the self proclaimed experts said that was a
terrible place. *Much to much power too close to the rest of my
avionics and electronics. *I now intend to place it on the underside
of the fuselage as far aft of the main gear housing as I can reach.
My question is, does it have to be mounted near the centerline, *I'd
rather not tangle with the overlap of the two fuselage halves. *How
far off the center line can I go before the biannual inspector will
object or I will lose effectiveness? *IT
Transponder Antenna Rick Fuller Soaring 6 January 30th 08 06:03 PM
Transponder Antenna Location [email protected] Soaring 15 January 17th 08 06:56 PM
VHF & Transponder antenna Steve Home Built 1 December 6th 04 04:29 PM
Oil on transponder antenna Bob Owning 12 May 9th 04 08:59 PM
Transponder and antenna Paolo Soaring 1 March 6th 04 03:32 AM
