Ok, how about this:
1) Cut hole in trailer under tailwheel 2) Cover rear fuslage and tail wheel area in plastic food wrap 3) Lay several layers of fiberglass cloth & resin over the hole in trailer 4) Lower plastic covered tailwheel onto the wet cloth letting it push down in the hole. 5) Block the tail up at the correct height. 6) Let the glass cure, trim, paint and attach with pop rivets. The result should be worthy of any dump truck. On Mar 30, 12:32*pm, " wrote: I almost clicked checkout on one of these.....and then I realized how comical this shiny and perfectly engineered Cobra part would look against the backdrop of my glider and trailer. It would be like putting a Ferrari seat in a dump truck. All joking aside thanks for the input.....just seemed a little overkill. Bryce |
On Mar 30, 1:58*pm, Guy Byars wrote:
Ok, how about this: 1) *Cut hole in trailer under tailwheel 2) *Cover rear fuslage and tail wheel area in plastic food wrap 3) *Lay several layers of fiberglass cloth & resin over the hole in trailer 4) *Lower plastic covered tailwheel onto the wet cloth letting it push down in the hole. 5) *Block the tail up at the correct height. 6) *Let the glass cure, trim, paint and attach with pop rivets. The result should be worthy of any dump truck. On Mar 30, 12:32*pm, " wrote: I almost clicked checkout on one of these.....and then I realized how comical this shiny and perfectly engineered Cobra part would look against the backdrop of my glider and trailer. It would be like putting a Ferrari seat in a dump truck. All joking aside thanks for the input.....just seemed a little overkill. Bryce- Hide quoted text - - Show quoted text - Or make a plug the shape of the cavity out of wood. sand smooth and fasten to smooth surface. Wax the heck out of it. Lay up glass and resin. Trim when cured. If you use epoxy you can just make the plug out of pink insulating foam and melt it out of the part when done. It should look home made enough to match your trailer. FWIW UH |
One of the Zuni medicine men had a spare one out of an old trailer so
it looks like I'm in good shape.....now its more like a vintage Ferrari tail light on a dump truck. This trailer is so ugly it looks like a spanish freight airplane I used to fly....... Thanks for the input guys......and thanks to Bob W. for the part. Bryce |
shipping glider to NZ-advice on securing glider in trailer | November Bravo | Soaring | 6 | November 1st 06 02:05 PM |
F.S. 3-glider trailer | Nigel Pocock | Soaring | 0 | September 29th 06 11:29 AM |
glider trailer Q | Ken Ward | Soaring | 10 | August 28th 06 04:27 PM |
glider trailer Q | Steve Leonard | Soaring | 1 | August 28th 06 05:29 AM |
wanted scott 3200 tailwheel /alaskan bushwheel tailwheel | phillip9 | Aviation Marketplace | 0 | June 6th 06 07:57 PM |
