C302 with LK8000
Old July 4th 11, 01:15 AM posted to rec.aviation.soaring
Andy[_1_]
Default C302 with LK8000
On Jul 3, 10:17*am, Brad wrote:
Does the LK8000 software work with the Cambridge 302? Interested to
know if the LK8000 running on an iPAC 310 can get accurate wind data
from the 302.
thanks,
Brad
302 defaults to 4800baud on every power up. HP 310 cannot operate at
4800baud. To make 302 communicate with 310 you will have to set it to
a higher baud rate every time you power it or use an intermediate mux.
Making the 2 play together was a winter project I abandoned as I was
expecting to have PowerFLARM by now.
Andy
Old July 4th 11, 01:42 AM posted to rec.aviation.soaring
Brad[_2_]
from the 302.
thanks,
Brad
302 defaults to 4800baud on every power up. *HP 310 cannot operate at
4800baud. *To make 302 communicate with 310 you will have to set it to
Andy
right now the panel is set up with a 310 and it is hooked up to a
Garmin puck GPS unit. I have a Tasman and an Ilec SB-8.
since I sold my Apis I have some cash to "upgrade" the
panel.........of course I've never flown with it, and it probably
would be just fine, but the idea of upgrading to some modern
instrumentation is appealing.
Brad
Old July 4th 11, 02:52 AM posted to rec.aviation.soaring
Darryl Ramm
from the 302.
thanks,
Brad
Andy
Anybody wanting to use a iPAQ 310, C302 and FLARM or similar setup
should really look at the K6MUX (http://www.k6-team.de/index.php?
option=com_content&view=article&id=62&Itemid=9). It can do baud rate
translation to solve the iPAQ 310 lack of 4800 baud issue, and much
more including merging in TAS data from the C302 and the traffic data
from the FLARM for consumption by the PDA/PNA software.
Darryl
LK8000 v2.0 released today PCool Soaring 17 January 18th 11 07:21 PM
iPAQ-310-LK8000-wind calculation Brad[_2_] Soaring 6 September 7th 10 11:05 PM
The LK8000 copyright issue is solved Max Kellermann Soaring 5 September 7th 10 06:50 PM
LK8000 questions Andy[_1_] Soaring 9 March 15th 10 11:10 AM
New LK8000 glide computer video PCool Soaring 6 October 12th 09 06:19 PM
