Hi,
The LXNAV Nano has been the popular unit lately. Customers seem to like that it is very small, has a built-in battery and antenna, and is very simple to use. I has also proven to be very reliable. I also sell the EW microRecorder, but I'd use the Nano myself - unless you have soaring friends using the EW - so you can help each other if necessary. But the EW is also very easy to use. Best Regards, -- Paul Remde Cumulus Soaring, Inc. "Vsoars" wrote in message ... I want to buy a back-up flight recorder. 63 invalid fixes on a long flight has convinced me that my Volkslogger won't always record the flight with the required accuracy. (I had the battery replaced last year but now I am having problems on about 1 out of 4 flights. The pattern of invalid fixes is- 4, 2, 30, 0,63, 23,21,49, 8, 10) |
On 29/07/2011 20:03, Paul Remde wrote:
Hi, The LXNAV Nano has been the popular unit lately. Customers seem to like that it is very small, has a built-in battery and antenna, and is very simple to use. I has also proven to be very reliable. I also sell the EW microRecorder, but I'd use the Nano myself - unless you have soaring friends using the EW - so you can help each other if necessary. But the EW is also very easy to use. Best Regards, One question about the Nano which I wasn't happy about - I may be wrong but it seems it does not have any internal memory like other loggers. The only place the trace gets stored is on the SD card. Other loggers with SD cards keep the trace in internal memory and just use the SD card for transfers. The Nano manual specifically says with a big red warning triangle next to it that although it has a removable SD card that removing the card is not recommened and also recommends always copying flights off the Nano in case of SD card failure. I believe the new Colibri II does have internal memory and just uses the SD card for transfering traces. May be a better bet once it is fully IGC approved? -- Nick Hill |
Hi Nick,
I don't see it is a problem that the Nano saves flight logs only on the microSD card. MicroSD cards are just as reliable as internal Flash memory. I have sold quite a few Nanos and so far the feedback has been very positive. It has proven very reliable. I fly with a Nano and I trust it. Best Regards, Paul Remde Cumulus Soaring, Inc. "Nick Hill" wrote in message ... On 29/07/2011 20:03, Paul Remde wrote: Hi, The LXNAV Nano has been the popular unit lately. Customers seem to like that it is very small, has a built-in battery and antenna, and is very simple to use. I has also proven to be very reliable. I also sell the EW microRecorder, but I'd use the Nano myself - unless you have soaring friends using the EW - so you can help each other if necessary. But the EW is also very easy to use. Best Regards, One question about the Nano which I wasn't happy about - I may be wrong but it seems it does not have any internal memory like other loggers. The only place the trace gets stored is on the SD card. Other loggers with SD cards keep the trace in internal memory and just use the SD card for transfers. The Nano manual specifically says with a big red warning triangle next to it that although it has a removable SD card that removing the card is not recommened and also recommends always copying flights off the Nano in case of SD card failure. I believe the new Colibri II does have internal memory and just uses the SD card for transfering traces. May be a better bet once it is fully IGC approved? -- Nick Hill |
On Mon, 01 Aug 2011 13:32:47 +0100, Nick Hill wrote:
The Nano manual specifically says with a big red warning triangle next to it that although it has a removable SD card that removing the card is not recommened and also recommends always copying flights off the Nano in case of SD card failure. That makes a lot of sense. Any analysis of the lifetime of SD card component lifetimes if its used for a relatively slow logging application (and recording 36 bytes once a second is pretty slow) shows that the contacts will wear out before the flash memory if its used to transfer logs from recorder to computer. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
New flight recorder - flyWithCE Flight Recorder | uros | Soaring | 12 | May 5th 09 08:31 PM |
In flight recorder | Lou | Piloting | 23 | March 24th 07 12:45 AM |
EW B-Model flight recorder | BDS | Soaring | 12 | August 19th 06 04:39 PM |
Back up Flight Recorder for US contests | Udo Rumpf | Soaring | 13 | April 6th 06 03:27 PM |
who does Flight Recorder calibration... | ken ward | Soaring | 4 | March 5th 04 02:28 AM |
