usually PTT switched are simply pushed down into the control stick grip and
not attached or installed with a nut or anything from below since it's almost impossible to get a wrench in there and you can't use a socket there either since it will already have the cables installed on the switch.this is not a problem since you are always pushing down on the switch, never lifting it...... a PTT switch is also a simple Normally open switch, 2 leads in and when you push the switch you merely make a completing of the two leads and the PTT circuit is then grounded telling the radio to transmit (keying the switch is like connecting the two wires to make one) I have these normally open switches that can be bought for just a couple $ at any electronics supply, but cheap switches are.well cheap, plastic and prone to failure.I also have expensive all metal switches with a very positive "click feature you can feel. http://www.wingsandwheels.com/page%202.htm ...I personally will only use these in my own aircraft..they are expensive, but always work and last .... tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Roger Worden" wrote in message ... Our club's PZL Swidnik PW5's push-to-talk switch is starting to fail. We looked at it briefly and it was not immediately obvious how it could be removed from the control stick and replaced. The maintenance manual was no help. Has anyone worked on one of these? __________ Information from ESET NOD32 Antivirus, version of virus signature database 6584 (20111028) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com __________ Information from ESET NOD32 Antivirus, version of virus signature database 6585 (20111029) __________ The message was checked by ESET NOD32 Antivirus. http://www.eset.com |
PUSH START | stanley adelson | Aviation Photos | 0 | July 15th 08 01:16 AM |
Push to Talk Switch | Jackal24 | Piloting | 23 | December 26th 04 10:01 PM |
Good panel mount COM radio and intercom w/push-to-talk? | John Huebbe | Home Built | 10 | November 27th 04 07:58 PM |
Portable Push-To-Talk switch help | Eric Brown | Owning | 9 | April 16th 04 04:26 AM |
Young Eagles push (USA) | John H. Campbell | Soaring | 0 | September 22nd 03 03:48 PM |
