Hi John,
Please see my notes below. Paul Remde "JohnDeRosa" wrote in message ... On Oct 30, 8:03 pm, "Paul Remde" wrote: The Oudie is supplied with a power/data cable that has an RJ45 connector, and an RJ45 to DB-9 connector. The RJ45 to DB-9 connector can be configured to work with the 302. It is a simple and free solution. The Oudie's power/data cable must be powered with 12V. Another option is the Oudie-PS5a-1 cable. It can be powered with 5V from the 302 and also pass 5V power to the Oudie. You can see details hehttp://www.cumulus-soaring.com/goddard.htm#Oudie-PS5a-1 Paul - How is the Oudie-PS5a-1 cable better than the supplied Naviter cable in the box? *** The Oudie's power/data cable must be powered with 12V. The Oudie-PS5a-1 cable is powered with 5V from the 302. Once installed, there are no functional differences that I'm aware of. With the supplied Naviter cable you have this setup; 12VDC = 302 = Oudie supplied cable (serial) = Oudie 12VDC = same Oudie supplied cable (12VDC to 5VDC converter) = Oudie With the Oudie-PS5a-1 cable you would have this setup; 12VDC = 302 = Oudie-PS5a-1 (serial + 5VDC) = Oudie So the Oudie-PS5a-1 solution is cleaner/neater. Is it electrically better? Better 12VDC to 5VDC conversion? Better RS-232 signal converter? *** Good questions. The only advantage is the simple and clean setup. It eliminates the need to connect the Oudie's power/data cable to 12V. The Oudie-PS5a-1 cable has been quite popular. I guess many people prefer the simple and clean approach. Thanks, John |
One other point I'd like to offer concerning the PS-5a-1 Cable. The
early models of the cable apparently were prone to breakage in the mini-USB plug (Oudie end of the cable). Mine broke internally after more than a year and Paul Remde and Goddard Electronics provided excellent support and an updated cable in a very short time. I highly commend and recommend them for their great customer service. The cable costs more than a little, but it does work extremely well and is a no-brainer to set up. Connect it to the serial port on the 302, plug the other end into the Oudie, set up the Oudie communication menu, and you're off to the races! |
Oudie | Steve Hunt | Soaring | 2 | July 8th 11 12:19 AM |
oudie | Steve Hunt[_2_] | Soaring | 0 | July 7th 11 08:58 AM |
FS: Naviter Oudie | Jonathan Hughes | Soaring | 2 | May 26th 11 06:55 PM |
Oudie with a LX 5000 | Randy[_2_] | Soaring | 2 | May 24th 10 10:48 AM |
