![]() On 11/5/2011 1:44 PM, Herbert kilian wrote: Thank you Luka, very interesting. Since you seem to a member of the development team, there are other questions I have. Of utmost interest is of course the amount of drag that the folded propeller creates and how it typically affects the glider's polar. As time goes on, you will most likely offer conversion kits for a number of gliders and I hope, my LS8-18 might be one of them. Also, what is the min height you must have for the shaft center of the prop from the ground, is that a restriction?(nobody should be tempted to ground launch or land with the prop running) Are gliders with 4 inch wheels OK? This would be a great kit to put on our experimental certified gliders here in the US! You probably heard this before but I had this idea about 5 years ago and made some sketches but never took the steps to verify the concept. Congratulations on making it work! You should try to get an article into 'Segelfliegen'. Herb If I understand correctly, you need a glider with a circular fuselage cross section at the transition between the spinner and the nose. However, most glider noses have an oval cross section. So a conversion kit would not work for many gliders (without modifying the shape of the nose). |
Luka is the original developer of the FES, together with his father
who is the Lak agent for Slovenia. The Lak factory has adopted the design and you can order new gliders from the factory with FES installed. They have a comparison with another glider suggesting that the drag of the folded propeller is negligible. I certainly cant tell any difference with mine being able to use the best lines of energy is far more important, and saving retrieves is a huge convenience. As well as Lak 17s, Luka has modified a Silent which had a non- circular nose. He had to develop a new shape, which was more cut back and redesigned/remade along the fuselage to arrive at a circular cross section at the point that the spinner/nose cone joined on. (I have a Lak 17a which Luka converted to FES it was the 6th, AIUI, and he has done a few more since. The Silent was in his workshop with work commenced when I took mine there in late 2010.) He developed the FES sustainer first on his own glider, then modified it before doing the Silent and mine, and meanwhile developed the more powerful motor and larger battery version for self launching, with which he won an award see his website. There is about 2 inch clearance from propeller to level ground on the basic Lak 17 with a 1 meter (39 inch) diameter propeller. I would not risk running the FES while moving on the ground except on smooth tarmac. In emergency, if it failed to stop running before landing, I would expect damage. I dont know if a modified undercarriage is planned for self launch with more clearance. I understand that Luka will consider retrofits to other gliders if they have suitable fuselages, but I would have thought that each different type is a major development effort, and the economics might be difficult for a one-off. If interested, you could always write and ask him. (I am not an agent for Luka, just a satisfied customer via the UK agents, Baltic Sailplanes, but I have written a couple of articles for the BGA magazine, Sailplane and Gliding, about the FES why I went for it, and how I have found it to sum up, very pleasing.) Chris N. |
Front Electric Sustainer | Greg Arnold[_3_] | Soaring | 22 | April 19th 10 09:46 PM |
Front Electric Sustainer | LimaZulu | Soaring | 25 | November 3rd 09 02:25 PM |
The HPH 304S Turbine sustainer glider | kd6veb | Soaring | 2 | September 23rd 09 05:10 AM |
would an electric sustainer be practical | Brad[_2_] | Soaring | 7 | July 24th 09 06:29 PM |
DG goes the sustainer option. | Paul | Soaring | 25 | June 4th 04 12:16 AM |
