Cliff Hilty wrote:
Im still trying to figure out why any of the files have to be "secure" ! Security is an illusion. I thought the intent of the OLC was to promote more people flying and friendly competition. Still scratching my head with all of this regulatory crap. Exactly my thought. Requiring so-called "secure" files limits the access to such a site artificially, and is no more than promoting the commercial logger industry. After all, we are all in it for the money and the girls right? If they want to cheat that bad let them. When manufacturers don't publish their cryptographic algorithms, it's a sure sign that they were not designed properly ("Snake Oil"), because good cryptography is one that withstands mathematical analysis. No IGC logger has a published verification procedure. The vendors publish closed-source EXE files for validation, as a black-box that magically tells you if a signature is correct. If you want to cheat, just buy two loggers. Both will have the same "private key" needed for signing. Open one (carefully, so it will not trigger key deletion), extract the private key, and use that private key to sign fake flights for the serial number of the second logger. (And that's not even exploiting potential mathematical flaws in the signature algorithm!) This kind of security is an illusion, and not worth the hundreds of dollars we spend on it. Max |
No practical cryptography is immune from mathematical analysis, ask the
NSA. It's just that the analysis may take a few hundred years at the present state of computing (but Moore's law applies). What makes you think that all flight recorders of one type have the same private key? Security is deemed to be sufficiently good to make it easier to break a World Record than to break the security; that's all that is needed. What the OLC requires is a matter for them, but since they are siiting in a room maybe continents away from the location of the flight, I guess they thing IGC file verification is necessary. Flight recorders make the OLC possible - don't knock it. At 07:36 24 November 2011, Max Kellermann wrote: Cliff Hilty wrote: Im still trying to figure out why any of the files have to be "secure" ! Security is an illusion. I thought the intent of the OLC was to promote more people flying and friendly competition. Still scratching my head with all of this regulatory crap. Exactly my thought. Requiring so-called "secure" files limits the access to such a site artificially, and is no more than promoting the commercial logger industry. After all, we are all in it for the money and the girls right? If they want to cheat that bad let them. When manufacturers don't publish their cryptographic algorithms, it's a sure sign that they were not designed properly ("Snake Oil"), because good cryptography is one that withstands mathematical analysis. No IGC logger has a published verification procedure. The vendors publish closed-source EXE files for validation, as a black-box that magically tells you if a signature is correct. If you want to cheat, just buy two loggers. Both will have the same "private key" needed for signing. Open one (carefully, so it will not trigger key deletion), extract the private key, and use that private key to sign fake flights for the serial number of the second logger. (And that's not even exploiting potential mathematical flaws in the signature algorithm!) This kind of security is an illusion, and not worth the hundreds of dollars we spend on it. Max |
Peter Purdie wrote:
No practical cryptography is immune from mathematical analysis, ask the NSA. It's just that the analysis may take a few hundred years at the present state of computing (but Moore's law applies). Are you sure you mean cryptanalysis? What you say sounds more like brute-forcing, and this is not what I mean. What makes you think that all flight recorders of one type have the same private key? If they had a different private key, then VALI.exe would need to include all public keys of all loggers sold. And you would have to update the VALI.exe each time the vendor generates new keys for new loggers he will sell, and each time somebody wants to have his logger repaired. Then think about what happens when a pilot sends a logger for repair, how will inserting a new key into the logger work? How will the existing VALI.exe on the OLC server get to know about this? While that would be technically possibly, and it would be possible to pregenerate thousands of keys in advance, I do not think any logger vendor has done this. Do you think they did? Max |
On Nov 24, 3:00*am, Max Kellermann wrote:
If they had a different private key, then VALI.exe would need to include all public keys of all loggers sold. *And you would have to update the VALI.exe each time the vendor generates new keys for new loggers he will sell, and each time somebody wants to have his logger repaired. *Then think about what happens when a pilot sends a logger for repair, how will inserting a new key into the logger work? *How will the existing VALI.exe on the OLC server get to know about this? While that would be technically possibly, and it would be possible to pregenerate thousands of keys in advance, I do not think any logger vendor has done this. Do you think they did? The vendors of IGC approved flight recorders are required to do this, as spelled out in the specification, which can be obtained here (unfortunately, the FAI web site is a bit wonky, right now): http://www.fai.org/igc-documents All flight recorders currently approved for "all flights" or "all badges and diplomas" have unique public/private key pairs for each unit. I, as a member of the IGC GNSS Flight Recorder Approval Committee, would like to see the algorithms standardized and the public keys openly distributed, but life is always a bit more complicated than it might seem... Marc |
Marc wrote:
All flight recorders currently approved for "all flights" or "all badges and diplomas" have unique public/private key pairs for each unit. Thanks Marc, I must have missed that part of the spec when I last read it. Interesting, I wonder how the public keys are distributed to the VALI.exe files. Whenever I see such "security by obscurity", I fear the worst. Usually, this assumption is close to the truth. I, as a member of the IGC GNSS Flight Recorder Approval Committee, would like to see the algorithms standardized and the public keys openly distributed, but life is always a bit more complicated than it might seem... Too sad, that's a big chance that was missed. It's extremely cumbersome or impossible to validate an IGC file on a machine other than Windows-i386. Max |
Valid OLC log out of SN-10b | Jim Archer | Soaring | 4 | June 11th 08 11:46 PM |
Valid OLC log out of SN-10b | Jim Archer | Soaring | 0 | June 11th 08 06:43 AM |
LX20-Secret Key Not Valid! | Ken Ward | Soaring | 6 | April 29th 06 08:22 PM |
Symbol question: Lake Huron sectional | David Kazdan | Piloting | 5 | July 17th 05 05:33 AM |
Airworthiness Cert Still Valid? | Carl Orton | Owning | 12 | February 13th 04 10:21 PM |
