Red V symbol (log file not valid) after OLC upload.
Old November 29th 11, 05:14 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Default Red V symbol (log file not valid) after OLC upload.
On Nov 28, 6:03*pm, Westbender wrote:
what is changing in the igc file format
effective 1-1-12 that would make that same program no longer work?
Sounds like they don't want to spend time fixing a Y2K sort of issue
with a cai to igc conversion program.
It already doesn't work. You don't have to wait til 1/1/2012.
When did it stop? I have a flight from 23 October that uploaded just
fine. Cambridge Model 20. In the 2012 OLC Season. May not be
working for you, but the conversion program I found works for me.
Granted, it sometimes takes two or maybe three uploads for it to be
successful, but it does work and is all green Vs.
Steve
Old November 30th 11, 04:51 PM posted to rec.aviation.soaring
Westbender
When did it stop? *I have a flight from 23 October that uploaded just
fine. *Cambridge Model 20. *In the 2012 OLC Season. *May not be
Steve
I guess you missed my meaning. Lots of people have been having
problems all season long due to this igc conversion work-around.
Although it will cease working for everyone at the end of the year.
Old December 1st 11, 03:45 PM posted to rec.aviation.soaring
Steve Leonard[_2_]
Nope, I didn't miss your meaning. It was never exactly easy for me
all season long, either. Sometimes it would successfully upload on
the first try, other flights would take 4 or 5 attempts of uploading
the exact same file using the exact same approach. Have no idea why,
it just was that way. I have seen the threads, and been involved in
helping several get things working for them. "Working" meaning that
after enough tries of uploading the same file, they would get the
green V.
As stated previously, I am going to see if the "support" that goes
away on January 1 is just a wrong file name from the file conversion
program.
Old December 1st 11, 04:40 PM posted to rec.aviation.soaring
Westbender
Nope, I didn't miss your meaning. *It was never exactly easy for me
all season long, either. *Sometimes it would successfully upload on
the exact same file using the exact same approach. *Have no idea why,
it just was that way. *I have seen the threads, and been involved in
helping several get things working for them. *"Working" meaning that
green V.
program.
Don't forget that they have a special process that deals with these
"hybrid" cai/igc files in a different way. They had to write special
code to validate them. These files are different from the "standard"
igc format. If they disable that special process, all bets are off.
Changing file names won't help in any way.
It sounds to me like they are going to retire that special validation
process for cai/igc hybrid files.
Valid OLC log out of SN-10b Jim Archer Soaring 4 June 11th 08 11:46 PM
Valid OLC log out of SN-10b Jim Archer Soaring 0 June 11th 08 06:43 AM
LX20-Secret Key Not Valid! Ken Ward Soaring 6 April 29th 06 08:22 PM
Symbol question: Lake Huron sectional David Kazdan Piloting 5 July 17th 05 05:33 AM
Airworthiness Cert Still Valid? Carl Orton Owning 12 February 13th 04 10:21 PM
