On Tue, 13 Dec 2011 11:35:44 +0100, "___P:Sir" wrote:
The 1 min timing (or 1½ min above 14.000 feet) - is that in Your opinion inbound or outbound leg? Doc 8168 says "outbound no wind" - but that might be a matter of definition, because all pro`s I asked, says Inbound...? regards.. P.sir In the US, the timing is for the inbound leg. The timing for the outbound leg gets adjusted to achieve the 1 minute or 1 1/2 minute inbound leg timing: Here is what the AIM says: The initial outbound leg should be flown for 1 minute or 1 1/2 minutes (appropriate to altitude). Timing for subsequent outbound legs should be adjusted, as necessary, to achieve proper inbound leg time. |
![]() "Ron Rosenfeld" skrev i en meddelelse ... On Tue, 13 Dec 2011 11:35:44 +0100, "___P:Sir" wrote: The 1 min timing (or 1½ min above 14.000 feet) - is that in Your opinion inbound or outbound leg? Doc 8168 says "outbound no wind" - but that might be a matter of definition, because all pro`s I asked, says Inbound...? regards.. P.sir In the US, the timing is for the inbound leg. The timing for the outbound leg gets adjusted to achieve the 1 minute or 1 1/2 minute inbound leg timing: Here is what the AIM says: The initial outbound leg should be flown for 1 minute or 1 1/2 minutes (appropriate to altitude). Timing for subsequent outbound legs should be adjusted, as necessary, to achieve proper inbound leg time. Thanks - if it is like that in the US, it surely must be in Europe as well? P.Sir |
On Tue, 13 Dec 2011 13:15:25 +0100, "___P:Sir" wrote:
Thanks - if it is like that in the US, it surely must be in Europe as well? P.Sir I have no way of knowing that. I have not trained in Europe and my only experience flying in Europe has been VFR. However, my brief perusal of some documentation I have from Jepp which references the ICAO document 8168 leads me to believe that such may NOT be the case in Europe. Corrections for wind effect paragraph seems to state that the adjustment required on the outbound leg, for heading and timing, is only such as to ensure the aircraft is established on the inbound track before passing the holding fix. This is quite different from the wording in the US AIM and implies that the inbound timing can be much less than the "still-air" 1 or 1 1/2 minutes. |
Holding Pattern Question | Dennis Johnson | Instrument Flight Rules | 60 | September 29th 07 06:52 AM |
While Holding for a Briefing Today... | Kyle Boatright | Piloting | 28 | May 21st 07 03:42 AM |
Bose X - $995 and holding... | [email protected] | Piloting | 23 | November 30th 05 12:57 AM |
Holding at CHS | Stuart King | Instrument Flight Rules | 3 | November 10th 03 07:52 PM |
Holding Pattern Entries | Dan Luke | Instrument Flight Rules | 17 | July 11th 03 05:18 AM |
