Thanks all, especially the BGA Aerotowing Guidance Notes linked to by
John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber |
On Jan 5, 10:58*am, Markus Graeber wrote:
Thanks all, especially the BGA Aerotowing Guidance Notes linked to by John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber Markus, About the Schweizer tow hooks on towplanes: While the Tost is without a doubt a better solution, and safer, we have been using the Schweizer in the US for a long time with few problems. Unless you fly a fleet of early trainers, the pitch up problem is probably more theoretical than real (for that matter, it would still be a problem with the Tost at low altitude, since you still have to release and recover!). That being said, one relatively simple fix is to invert the Schweizer release on the towplane, so the arm releases from the bottom (like on the glider). That way, upwards tension on the towrope caused by kiting is taken by the fixed arm and pivot, avoiding the problem of the towrope tension jamming the release arm. There is a 337 for this mod on Pawnees - Turf Soaring in Arizona developed it and they could help if interested. Regardless of the type of tow hook, a good briefing for both the tow pilot and glider pilot on the causes and consequences of this type of upset is essential! Cheers, Kirk |
Thanks Kirk, good point, I had heard about inverting the Schweizer tow
hook many years ago while still flying in ABQ but somehow forgot about it. We have to worry within the club about a PA-18 and a C-180, will check with the shop what it would take to invert them and if/what the legal ramifications in Colombia would be. Markus |
On Jan 5, 11:45*am, "kirk.stant" wrote:
On Jan 5, 10:58*am, Markus Graeber wrote: Thanks all, especially the BGA Aerotowing Guidance Notes linked to by John is very good stuff (by the same author as the mentioned book), I hadn't seen those yet even though we use quite a few BGA publications as a reference here. Just to clarify the situation, I am not going to write any legally binding regulations for the civil aviation authorities here (Aerocivil). The idea is a common sense set of rules for the federation level and a very specific set of rules for the club's operation based on the equipment and operating environment we have. Since we control these rules ourselves (much like the BGA does in the UK as well as the AU GFA and NZ GN as largely selfgoverning gliding organisations) it will be easy for us to change them quickly if needed. In addition, gliders here in Colombia are in practical terms treated like experimentals in the US so we can pretty much do as we please as long as we can reasonably assure it's safe to fly. If for example I want to install a nose hook I don't have to worry about STCs from the FAA/EASA, if I can dig up install instructions based on solid engineering I can just go ahead and install it. One example is the 2 LAK 12s we have in the club. They are known for lacking a bit of rudder so the owners got together and developed a slight extension to improve rudder effectiveness. Both LAKs also came without CG hooks so in order to get them ready for our winch launch operation I just organized the factory drawings for the CG hook install with the necessary specifications for the belly reinforcement. The actual install with the factory information is not that big of a deal if you have a good A&P around that has experience with fibreglass, no artificial legal barriers to worry about. Here, like all over the world, but sadly sometime more so, people have a habit of just improvising and out of convenience ingnore what should be common sense. Hence the need to be very specific, at least at the club level, based on a general set of reference rules. In addition, the club has a professional pilot school that is now starting to implement glider training into the general power pilot curriculum so we have to make every effort to develop a sound set of rules we can point to that can safe our ass and the school's certification when that accident that shouldn't happen eventually does. Hence my desire to make the best out of the situation and, free from any governmental tight jacket, develop a set of rules based on best practices and the latest research/developments. So for starters I would for example have no problem mandating that the school needs to replace the Schweizer aerotow hook on our PA-18 with a Tost for use for aerotow training while resticting the use of the Schweizer hook on our private C-180 to glider pilots with a certain aerotow experience level until it is replaced by a Tost. Taking into account the UK tests and fatal accidents that have happened due to the inability to trigger the release of a Schweizer hook under high loads I find it a bit mind boggling that these hooks are still legal in many countries and not being phased out on a mandatory basis. All the club's gliders have dedicated aerotow hooks so the only thing that needs to be done for now is mandating their use for aerotow to limit the risk of kiting. If someone eventually brings in a glider with a CG hook only (e.g. an ASW 20) we could then deal with it on a case by case basis on the federation or club level. As far as the aerotow ropes are concerned I am considering requiring a minimum rope strength (e.g. 1000 daN) and and weak links on both ends that comply with the max limits in the respective airplane's manual, I don't really see any valid excuse for not making that relatively small investment into proper safety equipment. On top of that would then be the recommendation to use a 400 or 500 daN weak link on the tow plane side not exceeding any limits imposed by the manufacturer while recommending 300 daN for most gliders or 400 daN for Open Class gliders with a take off weight of more than 600 kg (having in mind recent research and DG's weak link recommendation of half the glider's take-off weight). Keep it coming, Markus Graeber Markus, About the Schweizer tow hooks on towplanes: *While the Tost is without a doubt a better solution, and safer, we have been using the Schweizer in the US for a long time with few problems. *Unless you fly a fleet of early trainers, the pitch up problem is probably more theoretical than real (for that matter, it would still be a problem with the Tost at low altitude, since you still have to release and recover!). *That being said, one relatively simple fix is to invert the Schweizer release on the towplane, so the arm releases from the bottom (like on the glider). *That way, upwards tension on the towrope caused by kiting is taken by the fixed arm and pivot, avoiding the problem of the towrope tension jamming the release arm. *There is a 337 for this mod on Pawnees - Turf Soaring in Arizona developed it and they could help if interested. Regardless of the type of tow hook, a good briefing for both the tow pilot and glider pilot on the causes and consequences of this type of upset is essential! Cheers, Kirk You might also want to revisit the pros and cons of high versus low tow. Low tow seems likely to be safer for the tow pilot as kiting upsets are less likely. Mike |
Low tow very tricky in a glider with only a CoG hook.
John You might also want to revisit the pros and cons of high versus low tow. Low tow seems likely to be safer for the tow pilot as kiting upsets are less likely. Mike |
On Jan 5, 3:38*pm, John Roche-Kelly
wrote: Low tow very tricky in a glider with only a CoG hook. John NOT true. I've flown low tow with CG hooks for 35 years with no issues. UH |
FAA regulations - W&B | Arne | Piloting | 13 | March 15th 05 01:50 AM |
Jim Weir - aviation headset specifications | Rick Pellicciotti | Home Built | 2 | October 4th 04 07:34 PM |
Aerotow rope drogue chute? | John Galloway | Soaring | 18 | December 11th 03 05:37 AM |
Connecting Rod Specifications | Cambridge_Flyer | Home Built | 4 | November 18th 03 11:54 AM |
Huntair Pathfinder 2 specifications | Nigel Hodgson | General Aviation | 1 | October 16th 03 04:32 AM |
