#11
On Jan 16, 1:56*pm, Morgan wrote:
This pretty much nails what ended up working for me. *I ended up removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. *Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. *Overall things looked pretty good, but it got a good cleaning while I was in there. Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. *It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well. Thanks for the tips. Morgan On Jan 16, 9:23*am, rhwoody wrote: On Jan 11, 12:30*am, Morgan wrote: Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward- Hide quoted text - - Show quoted text - Changing the fluid every 6 or 8 years is a very good idea. I checked my system last year by having a helper (wife) pump the master cylinder a few strokes and then hold the pressure as I bled out the pressure at the brake.............just like we did in the 1934 Ford. You wouldn't believe what came out, thick gooey stuff that wasn't even red anymore! I had to repeat this for several cycles before the bled fluid started showing red fluid. I also replace my pads when they show less than 1/8" which can be easuly seen with a flashlight and mirror. Cheers, JJ |
On Jan 16, 6:05*pm, JJ Sinclair wrote:
On Jan 16, 1:56*pm, Morgan wrote: This pretty much nails what ended up working for me. *I ended up removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. *Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. *Overall things looked pretty good, but it got a good cleaning while I was in there. Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. *It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well. Thanks for the tips. Morgan On Jan 16, 9:23*am, rhwoody wrote: On Jan 11, 12:30*am, Morgan wrote: Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward- Hide quoted text - - Show quoted text - Changing the fluid every 6 or 8 years is a very good idea. I checked my system last year by having a helper (wife) pump the master cylinder a few strokes and then hold the pressure as I bled out the pressure at the brake.............just like we did in the 1934 Ford. You wouldn't believe what came out, thick gooey stuff that wasn't even red anymore! I had to repeat this for several cycles before the bled fluid started showing red fluid. I also replace my pads when they show less than 1/8" which can be easuly seen with a flashlight and mirror. Cheers, JJ I've been unable to get the Duo wheel brake to work as it should. This includes removing the entire system (caliper, lines, master cylinder) and operating it on the bench with a piece of metal to simulate the disc. In this configuration it works great - rock hard "brake pedal." But it has to be disassembled to go back in the glider, and there it is spongy again, no matter how much or how you bleed it. I thought the problem might be partial retraction of the pucks due to temperature changes, "potato chipped" disc, or vibration, so installed small springs behind the pucks to keep them lightly against the disc. No improvement. It helps to pump up the brake with the stick mounted brake lever if you have one, while in the landing pattern. Or cycle the air brakes fully if you don't have the stick grip. Another wheel brake problem with the Duo is a fundamental mechanical issue. The force required to cycle the speed brakes all the way open to the wheel brake actuation point gets higher as you slow down. While flying at pattern speed the spoilers stay open by air pressure, but as you slow down on the ground they get heavier as air speed no longer helps keep the handle back. With little or no airspeed the amount of force required to pull the handle all the way back is considerable, with little left over to apply brake. One solution I've employed for the latter is a long bungee cord that pulls back on the spoiler handle. But this has a couple significant safety issues that must be addressed. It must not be hooked up until landing, and the pilot must then keep his/her hand on the spoiler handle. A better procedure is to have the back seater help with the pull. |
On Jan 16, 7:39*pm, Karl Striedieck
wrote: On Jan 16, 6:05*pm, JJ Sinclair wrote: On Jan 16, 1:56*pm, Morgan wrote: This pretty much nails what ended up working for me. *I ended up removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. *Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. *Overall things looked pretty good, but it got a good cleaning while I was in there. Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. *It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well. Thanks for the tips. Morgan On Jan 16, 9:23*am, rhwoody wrote: On Jan 11, 12:30*am, Morgan wrote: Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level. I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve. The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it. Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble. Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning. Thanks, Morgan Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward- Hide quoted text - - Show quoted text - Changing the fluid every 6 or 8 years is a very good idea. I checked my system last year by having a helper (wife) pump the master cylinder a few strokes and then hold the pressure as I bled out the pressure at the brake.............just like we did in the 1934 Ford. You wouldn't believe what came out, thick gooey stuff that wasn't even red anymore! I had to repeat this for several cycles before the bled fluid started showing red fluid. I also replace my pads when they show less than 1/8" which can be easuly seen with a flashlight and mirror. Cheers, JJ I've been unable to get the Duo wheel brake to work as it should. This includes removing the entire system (caliper, lines, master cylinder) and operating it on the bench with a piece of metal to simulate the disc. In this configuration it works great - rock hard "brake pedal." But it has to be disassembled to go back in the glider, and there it is spongy again, no matter how much or how you bleed it. I thought the problem might be partial retraction of the pucks due to temperature changes, "potato chipped" disc, or vibration, so installed small springs behind the pucks to keep them lightly against the disc. No improvement. It helps to pump up the brake with the stick mounted brake lever if you have one, while in the landing pattern. Or cycle the air brakes fully if you don't have the stick grip. Another wheel brake problem with the Duo is a fundamental mechanical issue. The force required to cycle the speed brakes all the way open to the wheel brake actuation point gets higher as you slow down. While flying at pattern speed the spoilers stay open by air pressure, but as you slow down on the ground they get heavier as air speed no longer helps keep the handle back. With little or no airspeed the amount of force required to pull the handle all the way back is considerable, with little left over to apply brake. One solution I've employed for the latter is a long bungee cord that pulls back on the spoiler handle. But this has a couple significant safety issues that must be addressed. It must not be hooked up until landing, and the pilot must then keep his/her hand on the spoiler handle. A better procedure is to have the back seater help with the pull.- Hide quoted text - - Show quoted text - I have had similar problems with the Grob 103, just couldn't get the air bubble to break loose. You might try tilting the fuselage as far as possible (away from the brake side), then bleed the brakes. This might allow the bubble to rise up to the master cylinder. See you at Parowan, JJ |
![]() Quote:
Sounds like a more serios issue is at foot though bagger |
On Jan 18, 5:36*pm, bagmaker
wrote: 'JJ Sinclair[_2_ Wrote: ;807799']On Jan 16, 7:39*pm, Karl Striedieck wrote:- On Jan 16, 6:05*pm, JJ Sinclair wrote: - On Jan 16, 1:56*pm, Morgan wrote:- -- This pretty much nails what ended up working for me. *I ended up removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. *Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. *Overall things looked pretty good, but it got a good cleaning while I was in there.-- -- Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. *It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well.-- -- Thanks for the tips.-- -- Morgan-- -- On Jan 16, 9:23*am, rhwoody wrote:-- -- On Jan 11, 12:30*am, Morgan wrote:-- -- Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level.-- -- I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve.-- -- The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it.-- -- Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble.-- -- Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning.-- -- Thanks,-- -- Morgan-- -- Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward- Hide quoted text --- -- - Show quoted text --- - Changing the fluid every 6 or 8 years is a very good idea. I checked my system last year by having a helper (wife) pump the master cylinder a few strokes and then hold the pressure as I bled out the pressure at the brake.............just like we did in the 1934 Ford. You wouldn't believe what came out, thick gooey stuff that wasn't even red anymore! I had to repeat this for several cycles before the bled fluid started showing red fluid. I also replace my pads when they show less than 1/8" which can be easuly seen with a flashlight and mirror. Cheers, JJ- I've been unable to get the Duo wheel brake to work as it should. This includes removing the entire system (caliper, lines, master cylinder) and operating it on the bench with a piece of metal to simulate the disc. In this configuration it works great - rock hard "brake pedal." But it has to be disassembled to go back in the glider, and there it is spongy again, no matter how much or how you bleed it. I thought the problem might be partial retraction of the pucks due to temperature changes, "potato chipped" disc, or vibration, so installed small springs behind the pucks to keep them lightly against the disc. No improvement. It helps to pump up the brake with the stick mounted brake lever if you have one, while in the landing pattern. Or cycle the air brakes fully if you don't have the stick grip. Another wheel brake problem with the Duo is a fundamental mechanical issue. The force required to cycle the speed brakes all the way open to the wheel brake actuation point gets higher as you slow down. While flying at pattern speed the spoilers stay open by air pressure, but as you slow down on the ground they get heavier as air speed no longer helps keep the handle back. With little or no airspeed the amount of force required to pull the handle all the way back is considerable, with little left over to apply brake. One solution I've employed for the latter is a long bungee cord that pulls back on the spoiler handle. But this has a couple significant safety issues that must be addressed. It must not be hooked up until landing, and the pilot must then keep his/her hand on the spoiler handle. A better procedure is to have the back seater help with the pull.- Hide quoted text - - Show quoted text -- I have had similar problems with the Grob 103, just couldn't get the air bubble to break loose. You might try tilting the fuselage as far as possible (away from the brake side), then bleed the brakes. This might allow the bubble to rise up to the master cylinder. See you at Parowan, JJ Old motorcycle trick is to elevate the mastercylinder and lever then cable tie the lever with some pressure overnight. Any microscopic bubbles will come out then. Sounds like a more serios issue is at foot though bagger -- bagmaker My next attempt to get a solid "brake pedal" will be to unmount the master cylinder and elevate it so that the brake line is as close to vertical as possible. As it lies in the ship the line is about horizontal and not much better with the tail raised. I'll try Bagger's suggestion as well if necessary. KS |
On Jan 18, 6:44*pm, Karl Striedieck
wrote: On Jan 18, 5:36*pm, bagmaker wrote: 'JJ Sinclair[_2_ Wrote: ;807799']On Jan 16, 7:39*pm, Karl Striedieck wrote:- On Jan 16, 6:05*pm, JJ Sinclair wrote: - On Jan 16, 1:56*pm, Morgan wrote:- -- This pretty much nails what ended up working for me. *I ended up removing the whole system from the ship and flushing it forwards and backwards to make sure there wasn't any old fluid or particles in the system. *Popped the piston out and inspected it and the cylinder wall for corrosion and pitting. *Overall things looked pretty good, but it got a good cleaning while I was in there.-- -- Funny, you'll jump through all sorts of hoops and delays to avoid doing it the "hard way" and in the end that was the least traumatic and fastest way to get it to work. *It took me way longer than it should have, but the upside is that I know my braking system inside an out now and it is time for new pads as well.-- -- Thanks for the tips.-- -- Morgan-- -- On Jan 16, 9:23*am, rhwoody wrote:-- -- On Jan 11, 12:30*am, Morgan wrote:-- -- Looking for advice on bleeding the brakes on my Duo with the tost 30-9 caliper. *I replaced a shot bleeder valve with a new stahlbus valve, but after futzing with the system for over an hour, I can't get the brake to firm up to an acceptable level.-- -- I've tried using a suction device to pull fluid (Dot 4 in the Duo) down through the line. *I've also gone with my normal old standby of pushing fluid up through the brake using a syringe. *The Stahlbus valve is not working as advertised or rather the brake isn't. *The brake doesn't seem to be creating enough pressure to overcome the spring tension on the check valve.-- -- The best I've been able to get to so far is a fairly spongy grip on the rotor. Enough that turning by hand isn't possible, but it doesn't feel like it would slow you down much when you needed it.-- -- Basically it just doesn't feel like the master cylinder is drawing fluid in or maybe there is a hidden air bubble.-- -- Any thoughts from the internet hive on the quirks of this beast? It's certainly been a much greater hassle than I expected. *I'm guessing at this point that either there is a trick that I don't know about or something is malfunctioning.-- -- Thanks,-- -- Morgan-- -- Hi All, *I have owned a lot of SH gliders and have had success doing the following - unbolt the brake cylinder and raise it up so there is no "loop" in the brake line - so the path from the brake calipers to the brake cylinder goes only uphill - first try to actuate the brake cylinder lever - sometimes this will "burp" the air bubble up into the brake cylinder - otherwise fill fluid from the bottom nipple until the air bubble goes into the brake cylinder reservoir - *most times the air bubble will burp into the reservoir and no filling is necessary - good luck, Ralph Woodward- Hide quoted text --- -- - Show quoted text --- - Changing the fluid every 6 or 8 years is a very good idea. I checked my system last year by having a helper (wife) pump the master cylinder a few strokes and then hold the pressure as I bled out the pressure at the brake.............just like we did in the 1934 Ford. You wouldn't believe what came out, thick gooey stuff that wasn't even red anymore! I had to repeat this for several cycles before the bled fluid started showing red fluid. I also replace my pads when they show less than 1/8" which can be easuly seen with a flashlight and mirror. Cheers, JJ- I've been unable to get the Duo wheel brake to work as it should. This includes removing the entire system (caliper, lines, master cylinder) and operating it on the bench with a piece of metal to simulate the disc. In this configuration it works great - rock hard "brake pedal." But it has to be disassembled to go back in the glider, and there it is spongy again, no matter how much or how you bleed it. I thought the problem might be partial retraction of the pucks due to temperature changes, "potato chipped" disc, or vibration, so installed small springs behind the pucks to keep them lightly against the disc. No improvement. It helps to pump up the brake with the stick mounted brake lever if you have one, while in the landing pattern. Or cycle the air brakes fully if you don't have the stick grip. Another wheel brake problem with the Duo is a fundamental mechanical issue. The force required to cycle the speed brakes all the way open to the wheel brake actuation point gets higher as you slow down. While flying at pattern speed the spoilers stay open by air pressure, but as you slow down on the ground they get heavier as air speed no longer helps keep the handle back. With little or no airspeed the amount of force required to pull the handle all the way back is considerable, with little left over to apply brake. One solution I've employed for the latter is a long bungee cord that pulls back on the spoiler handle. But this has a couple significant safety issues that must be addressed. It must not be hooked up until landing, and the pilot must then keep his/her hand on the spoiler handle. A better procedure is to have the back seater help with the pull.- Hide quoted text - - Show quoted text -- I have had similar problems with the Grob 103, just couldn't get the air bubble to break loose. You might try tilting the fuselage as far as possible (away from the brake side), then bleed the brakes. This might allow the bubble to rise up to the master cylinder. See you at Parowan, JJ Old motorcycle trick is to elevate the mastercylinder and lever then cable tie the lever with some pressure overnight. Any microscopic bubbles will come out then. Sounds like a more serios issue is at foot though bagger -- bagmaker My next attempt to get a solid "brake pedal" will be to unmount the master cylinder and elevate it so that the brake line is as close to vertical as possible. As it lies in the ship the line is about horizontal and not much better with the tail raised. I'll try Bagger's suggestion as well if necessary. KS That's the tactic I finally chose. The biggest hassle is dealing with the handbrake cables when you reconnect them, but total time to pull the master cylinder was only a few minutes. Excluding the seat removal, but I already had that out for cleaning the glider for it's annual. With the master cylinder free and practically a vertical run from the caliper to the master cylinder, I was able to get good pressure and a firm pedal, but I'll see tomorrow when I get the new pads installed and can properly adjust the brake throw with the dive brakes. I've always had powerful brakes on my Duo until the last time I flew it and they were a bit spongy. Just felt like they needed bleeding though. I've certainly learned way more about the braking system in the Duo than I'd thought I'd need to know for a "simple" bleeding job. |
Lots of snippage
Old motorcycle trick is to elevate the mastercylinder and lever then cable tie the lever with some pressure overnight. Any microscopic bubbles will come out then. Sounds like a more serios issue is at foot though bagger -- bagmaker Does air dissolve in brake fluid? Wouldn't pressurizing the system overnight cause the air bubbles to dissolve only to come out later after the pressure is relieved? This is the reason for decompression during deep dives. My glider has a mechanical brake (which works quite well, thank you), but on my motorcycles, I service the brakes with an oil can full of brake fluid. I draw off as much fluid as I can from the master cylinder and then, using the oil can, pump it up from the bleed valve at the caliper. It's pretty easy on the bike to remove the caliper and hold it so that the hose is at the top, allowing the air to go up the brake line to the master cylinder where it'll escape as a bubble. |
I have nearly the same problem on my V2C. 2 seasons ago I noticed
something dripping from the vent hole in the bottom of the fuselage. Until then my brake had been rock hard. Inspection showed that yellow brake fluid was leaking from the master cylinder and gum had formed around the master. Fluid probably 14 years old. I could not find a revision set and decided to buy a new Magura master (from the motorcycle store, used on many BMWs). Instead of a 20mm master, I got a 16mm master. The 16mm master should only give a bit more travel. Re-installed and had the same described spongyness. Took the Cleveland caliper apart and observed significant corrosion on the caliper, less on the piston. Sanded carefully a bit, installed new O-ring and re-mounted. Still the spongyness, even after pumping a pint of new clean fluid both ways (up and down). Part of the problem is that the piston retracts a bit upon release of the brake handle, instead of taking new fluid from the master reservoir to fill the void. I need to do more work before the season starts Question to Bumper: Can the brass liners and anodized piston be retrofitted ? Where ? 3U |
On Jan 23, 10:03*pm, Three Uniform wrote:
I have nearly the same problem on my V2C. 2 seasons ago I noticed something dripping from the vent hole in the bottom of the fuselage. Until then my brake had been rock hard. Inspection showed that yellow brake fluid was leaking from the master cylinder and gum had formed around the master. Fluid probably 14 years old. I could not find a revision set and decided to buy a new Magura master (from the motorcycle store, used on many BMWs). Instead of a 20mm master, I got a 16mm master. The 16mm master should only give a bit more travel. Re-installed and had the same described spongyness. Took the Cleveland caliper apart and observed significant corrosion on the caliper, less on the piston. Sanded carefully a bit, installed new O-ring and re-mounted. Still the spongyness, even after pumping a pint of new clean fluid both ways (up and down). Part of the problem is that the piston retracts a bit upon release of the brake handle, instead of taking new fluid from the master reservoir to fill the void. I need to do more work before the season starts Question to Bumper: Can the brass liners and anodized piston be retrofitted ? Where ? 3U I saved this link last time Bumper recommended it. http://www.brakecylinder.com/index.htm Good luck with the brakes. You may want to look at replacing the brake line. The one SH used was disintegrating & the brake works much better after replacing it with a stainless braided unit. The Hot Rod crowd has great sources. http://www.jegs.com/i/JEGS-Performan...ductId=1117442 http://www.jegs.com/webapp/wcs/store... hTerm=670501 Cheers, Craig |
![]() Changing topic to "problems with Cleveland Brake Calipers" Thanks Craig for posting Bumpers's link again. I called Joe at Sierra Specialty Automotive (brakecylinder.com) He stated that his insurance company does not allow him anymore to work on aviation parts. (The part could of course be from a historic tractor) But more importantly, he concluded that the composition of the aviation alloys does not match with his process and procedures of fitting sleeves. He had to deal with a number of returns. So, he is not providing this service anymore. In talking to Joe, another point came up. The Cleveland caliper has the O-ring on the piston. The sealing is against the bore in the caliper. Therefore the surface of the piston is not that relevant, but the condition of the bore is very much so. In his opinion, the bore should have a polished finish. When I dis-assembled mine, it definitely did not have a polished finish. Apart from some corrosion, there seemed to be a fine, regular, ringed structure in the surface of the bore. Any ideas on this ? 3U |
brake bleeding | Pintlar | Home Built | 15 | April 7th 10 03:01 AM |
bleeding brake help | Pintlar | Home Built | 8 | November 7th 09 12:41 PM |
Engine bleeding | [email protected] | Piloting | 4 | December 9th 04 04:38 AM |
Engine bleeding | [email protected] | Piloting | 0 | December 8th 04 09:22 AM |
Bleeding brakes on Tripacer | Corky Scott | Piloting | 2 | July 30th 03 08:11 PM |
