2-32 Canopy Frame
Old March 6th 12, 06:20 AM posted to rec.aviation.soaring
aerodyne
Default 2-32 Canopy Frame
On Mar 5, 8:18*pm, olddogcirrus wrote:
Hi All,
Had an incident today where a 2-32 canopy flew open in flight while on
tow and hitting some rotor. *Long story short, successful landing, but
the cromoly tubing frame of the canopy is severely sprung and needs to
be repaired or replaced. *Would anyone happen to know where abouts of
a 2-32 canopy frame? *Sheet metal and plexiglass parts not necessarily
needed, just the steel frame....
Thanks
Steve
Same thing happened to us a few years back - the lugs on the cocpit
rail get worn, esp if the frame is sprung a little, as most are. Call
Les at K&L soaring for parts and dwgs.
We had wing and tail damage,as well. Hope that did not happen to
you. Glide ratio was severly affected and did not quite make it back
to the runway...
Old March 6th 12, 04:08 PM posted to rec.aviation.soaring
GARY BOGGS
How do we contact you?
Boggs
Old March 6th 12, 04:25 PM posted to rec.aviation.soaring
GARY BOGGS
Got it.
Boggs
Wanted. ASK-13 sport canopy or frame Burt Compton - Marfa Soaring 0 February 14th 11 01:13 PM
WANTED: 1-26A, B or C Canopy frame Ted[_2_] Soaring 0 July 12th 08 09:50 AM
Cirrus canopy frame repair Louw Pieters Soaring 0 May 29th 04 06:09 AM
Fitting canopy frame to fuselage advice Deputy Dog Soaring 5 July 27th 03 04:08 AM
Need clean 1-26E canopy frame Robert de León Soaring 0 July 22nd 03 07:16 PM
