Antenna Install in a Metal Glider
Old April 8th 12, 03:18 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default Antenna Install in a Metal Glider
On Apr 8, 9:12*am, Markus Graeber wrote:
Happy Easter everyone! We have a IS-28B2 Twin Lark which we use quite a bit for instruction, it is good for spinning and intro into flying complex gliders (flaps & retractable gear). It is due for a complete overhaul which will include a new radio with a repeater control unit in the back for the instructor.
Since weŽll then be re-working the whole radio install anyway I have been considering doing something about the dragmaster factory radio antenna that looks more like a car antenna installed ontop of the fuselage tail boom.. For you experts out there what would be your recommendation for an interior radio antenna install (or a low drag exterior install) in an all metal glider like the Twin Lark?
Many thanks in advance,
Markus Graeber
Aeroclub de Colombia
Partial solution: 90 deg bent whip http://store.wagaero.com/product_inf...roducts_id=459
Depending on the material your current antenna is made from, you might
try a tubing bender.
The radiated power from a whip antenna comes disproportionately from
the "bottom" quarter, which is why this works. It's still ugly, but
the drag is much lower.
T8
PowerFlarm antenna install Sam Zimmerman Soaring 10 November 11th 10 09:54 PM
Antenna install [email protected] Piloting 5 May 26th 08 03:48 PM
Antenna install [email protected] Owning 5 May 26th 08 03:48 PM
Antenna install [email protected] Home Built 5 May 26th 08 03:48 PM
antenna installation in a glider? ken ward Soaring 5 May 19th 04 07:02 PM
