In article , Bill
McClain wrote: And this got me wondering: Does anybody test to see how high up you can successfully autorotate from? Is there an actual record for this? Sounds like a self correcting problem. If you are too high to autorotate, you will very soon be much lower. Ummm, yeah, I guess so, but...seriously, is it even possible to try and keep the RPMs up by diving and turning...I guess WITH the direction of rotor spin...trying to maintain as much inertia in the mast and blades before they lose so much torque as to be unable to provide any lift to pull out of the dive and try to flare close to the ground? I'm pretty much talking through my hat speculating like this; I don't really know all that much about helicopters (other than that I'm not all that keen on riding in one). Believe it or not, the problem is just the opposite. In a high altitude autorotation the rotor tends to overspeed if you don't keep an eye on it and a small application of collective pitch is necessary from time to time to keep it within limits. Turning and diving are unnecessary. When I was instructing at Fort Rucker many moons ago we would take students to 10,000 MSL in a UH-1H and let them play with the autorotative characteristics. The airspeed for minimum rate of descent in the UH-1 is 63 knots indicated while the maximum glide distance is attained at 98 knots. From 10,000 feet the student has lots of time to vary the airspeed and get a feel for different rates of descent before a power recovery is required. We did touchdown autorations every day in the training cycle, but were limited to six per student per day because they are so intense to a student that any training benefit beyond that is negligible. On days when I had three students, I would do eighteen touchdown autorotations from 1000' to a concrete runway and not think a thing about it. ************************************************** ********************** http://travel.howstuffworks.com/helicopter.htm What is autorotation? Autorotation is a condition where the main rotor is allowed to spin faster than the engine driving it. How is that achieved? It is actually quite simple. All helicopters are fitted with a free wheeling unit between the engine and the main rotor, usually in the transmission. This free wheeling unit can come in different forms but one of the most popular is the sprag clutch. The free wheeling unit will allow the engine to drive the rotors but not allow the rotors to turn the engine. When the engine/s fail the main rotor will still have a considerable amount of inertia and will still want to turn under its own force and through the aerodynamic force of the air through which it is flying. The free wheeling unit is designed in such a way to allow the main rotor to now rotate of its own free will regardless of engine speed. This principle is the same reason that if you are in your car and you push your clutch in, or put it into neutral while the car is still moving, the car will coast along under it's own force. This occurs regardless of what you do to the accelerator pedal. Controlled Descent ? The next question you are probably asking yourself is: "Does the pilot retain control of the helicopter?" The answer is yes. The pilot will still have complete control of his descent and his flight controls. The majority of helicopters are designed with a hydraulic pump mounted on the main transmission. As the rotor will still be turning the transmission, the pilot will still have hydraulically assisted flight controls. The pilot will be able to control his descent speed and main rotor RPM with his collective control stick. He will be able to control his main rotor RPM by increasing the collective pitch, which will increase drag on the rotor blades and thereby slow the main rotor. If he needs to increase his rotor RPM, he can decrease his collective pitch therefore decreasing drag. The pilot will usually be able to find a suitable area for a safe landing by normal manipulation of his cyclic control stick and his directional, or tail rotor pedals. Larger helicopters will usually have a generator mounted on the transmission that will still provide electrical power for flight and communication systems. What happens to Torque Effect ? Torque effect is the aircraft's tendency to rotate in the opposite direction to the main rotor due to Newton's third law "Every action has an equal and opposite reaction". This is the reason why we need a tail rotor or some other form of anti-torque control. The question at hand is what happens to torque effect during autorotation? Well torque effect is directly proportional to the amount of force driving the main rotor, so when when the engine fails the amount of force driving the main rotor instantaneously decreases and therefore the torque effect decreases. This being the case the fuselage of the helicopter will tend to rotate due to the sudden lack of torque effect. The pilot will therefore have to immediately manipulate his directional pedals to overcome this problem and retain control of his aircraft. Conclusion So in conclusion if your helicopter's engine/s should fail it is not just possible, but quite easy for the pilot to retain control and land safely and gently. This is the reason I believe that helicopters are far safer and more fun to fly in than fixed wing aircraft. A fixed wing aircraft will always need forward speed to safely land, with or without an engine operating. A helicopter can be made to land with zero forward speed whether the engine is operating or not. |
On Wed, 10 Mar 2004 06:06:46 GMT, "John‰]*
************************************************** *************" wrote: In article , Bill McClain wrote: And this got me wondering: Does anybody test to see how high up you can successfully autorotate from? Is there an actual record for this? Sounds like a self correcting problem. If you are too high to autorotate, you will very soon be much lower. Ummm, yeah, I guess so, but...seriously, is it even possible to try and keep the RPMs up by diving and turning...I guess WITH the direction of rotor spin...trying to maintain as much inertia in the mast and blades before they lose so much torque as to be unable to provide any lift to pull out of the dive and try to flare close to the ground? I'm pretty much talking through my hat speculating like this; I don't really know all that much about helicopters (other than that I'm not all that keen on riding in one). Believe it or not, the problem is just the opposite. In a high altitude autorotation the rotor tends to overspeed if you don't keep an eye on it and a small application of collective pitch is necessary from time to time to keep it within limits. Turning and diving are unnecessary. When I was instructing at Fort Rucker many moons ago we would take students to 10,000 MSL in a UH-1H and let them play with the autorotative characteristics. The airspeed for minimum rate of descent in the UH-1 is 63 knots indicated while the maximum glide distance is attained at 98 knots. From 10,000 feet the student has lots of time to vary the airspeed and get a feel for different rates of descent before a power recovery is required. We did touchdown autorations every day in the training cycle, but were limited to six per student per day because they are so intense to a student that any training benefit beyond that is negligible. On days when I had three students, I would do eighteen touchdown autorotations from 1000' to a concrete runway and not think a thing about it. I used to watch students at Rucker flare and sometimes hit their tail stingers on the ground after autorotations at tac fields, and one day I saw an instructor gesticulating wildly at a WOC and grabbing the controls as the Huey went skidding down a paved strip in a semi-controlled run-on landing. Another day I saw a near mid-air between a WOC-flown UH-1 and a Flatiron bird - if they would have hit they would have landed right on top of the old hospital. The last autoration I was involved with was due to a fuel-pump fire in a Huey in Korea, with the end result that we landed on a sandbar in a river up near the DMZ, nearly hitting some high-tension lines in fog and drizzle, and spent a long cold winter night waiting for rescue. John Hairell |
![]() "John Hairell" wrote in message ... On Wed, 10 Mar 2004 06:06:46 GMT, "John?] " wrote: In article , Bill McClain wrote: And this got me wondering: Does anybody test to see how high up you can successfully autorotate from? Is there an actual record for this? Sounds like a self correcting problem. If you are too high to autorotate, you will very soon be much lower. Ummm, yeah, I guess so, but...seriously, is it even possible to try and keep the RPMs up by diving and turning...I guess WITH the direction of rotor spin...trying to maintain as much inertia in the mast and blades before they lose so much torque as to be unable to provide any lift to pull out of the dive and try to flare close to the ground? I'm pretty much talking through my hat speculating like this; I don't really know all that much about helicopters (other than that I'm not all that keen on riding in one). Believe it or not, the problem is just the opposite. In a high altitude autorotation the rotor tends to overspeed if you don't keep an eye on it and a small application of collective pitch is necessary from time to time to keep it within limits. Turning and diving are unnecessary. When I was instructing at Fort Rucker many moons ago we would take students to 10,000 MSL in a UH-1H and let them play with the autorotative characteristics. The airspeed for minimum rate of descent in the UH-1 is 63 knots indicated while the maximum glide distance is attained at 98 knots. From 10,000 feet the student has lots of time to vary the airspeed and get a feel for different rates of descent before a power recovery is required. We did touchdown autorations every day in the training cycle, but were limited to six per student per day because they are so intense to a student that any training benefit beyond that is negligible. On days when I had three students, I would do eighteen touchdown autorotations from 1000' to a concrete runway and not think a thing about it. I used to watch students at Rucker flare and sometimes hit their tail stingers on the ground after autorotations at tac fields, and one day I saw an instructor gesticulating wildly at a WOC and grabbing the controls as the Huey went skidding down a paved strip in a semi-controlled run-on landing. Another day I saw a near mid-air between a WOC-flown UH-1 and a Flatiron bird - if they would have hit they would have landed right on top of the old hospital. The last autoration I was involved with was due to a fuel-pump fire in a Huey in Korea, with the end result that we landed on a sandbar in a river up near the DMZ, nearly hitting some high-tension lines in fog and drizzle, and spent a long cold winter night waiting for rescue. John Hairell John, you might be able to answer a question I have regarding autorotations. My late brother experienced exactly one serious mishap in a helo (outside getting shot down once in Vietnam and having various small arms rounds zing through the cabin on other occasions). It involved an autorotation in a Schweizer 300C (read as Hughes 300/TH-55). He was checking out a cop from the (unnamed big city) police department, which had recently purchased a couple of 300C's for law enforcement work. Apparently the cop, who was also a part-time ARNG Cobra pilot, had come through flight school during the post-TH-55 days. During the autorotation, the guy apparently treated the 300C like it was a Cobra, which I gather is a bad thing to do, and when my brother tried to take back over the guy froze up and fought the controls--resulting in a hard landing and rolling the aircraft onto its side (he compounded that by stomping all over my brother, who was left on the lower side, in his haste to depart the now-stationary aircraft). Any idea what the guy could have done that led to my brother trying to take control? And FYI--the accident investigation cleared my brother in the incident, so I gather that his side of the story was the way it happened. Thanks. Brooks |
On Wed, 10 Mar 2004 13:30:44 -0500, "Kevin Brooks"
wrote: John, you might be able to answer a question I have regarding autorotations. My late brother experienced exactly one serious mishap in a helo (outside getting shot down once in Vietnam and having various small arms rounds zing through the cabin on other occasions). It involved an autorotation in a Schweizer 300C (read as Hughes 300/TH-55). He was checking out a cop from the (unnamed big city) police department, which had recently purchased a couple of 300C's for law enforcement work. Apparently the cop, who was also a part-time ARNG Cobra pilot, had come through flight school during the post-TH-55 days. During the autorotation, the guy apparently treated the 300C like it was a Cobra, which I gather is a bad thing to do, and when my brother tried to take back over the guy froze up and fought the controls--resulting in a hard landing and rolling the aircraft onto its side (he compounded that by stomping all over my brother, who was left on the lower side, in his haste to depart the now-stationary aircraft). Any idea what the guy could have done that led to my brother trying to take control? And FYI--the accident investigation cleared my brother in the incident, so I gather that his side of the story was the way it happened. Kevin, I've been talking about this with a well-know Vietnam-era cav pilot and he says that there's not a whole lot of difference between a TH-55/Hughes 300 "Mattel Messerschmitt" as far as autorotation. The Cobra flares higher and longer, and TH-55s level the skids prior to touchdown. He says it sounds like a late "recovery" to him. If you have a date and location we could dig out the NTSB accident report and see what the official cause was. John Hairell |
![]() "John Hairell" wrote in message news ![]() On Wed, 10 Mar 2004 13:30:44 -0500, "Kevin Brooks" wrote: John, you might be able to answer a question I have regarding autorotations. My late brother experienced exactly one serious mishap in a helo (outside getting shot down once in Vietnam and having various small arms rounds zing through the cabin on other occasions). It involved an autorotation in a Schweizer 300C (read as Hughes 300/TH-55). He was checking out a cop from the (unnamed big city) police department, which had recently purchased a couple of 300C's for law enforcement work. Apparently the cop, who was also a part-time ARNG Cobra pilot, had come through flight school during the post-TH-55 days. During the autorotation, the guy apparently treated the 300C like it was a Cobra, which I gather is a bad thing to do, and when my brother tried to take back over the guy froze up and fought the controls--resulting in a hard landing and rolling the aircraft onto its side (he compounded that by stomping all over my brother, who was left on the lower side, in his haste to depart the now-stationary aircraft). Any idea what the guy could have done that led to my brother trying to take control? And FYI--the accident investigation cleared my brother in the incident, so I gather that his side of the story was the way it happened. Kevin, I've been talking about this with a well-know Vietnam-era cav pilot and he says that there's not a whole lot of difference between a TH-55/Hughes 300 "Mattel Messerschmitt" as far as autorotation. The Cobra flares higher and longer, and TH-55s level the skids prior to touchdown. He says it sounds like a late "recovery" to him. If you have a date and location we could dig out the NTSB accident report and see what the official cause was. I am guessing around the '88 to '90 timeframe. Pretty sure the accident occured at the Schweizer plant location in Elmira, NY (he was employed by Schweizer up until he died of cancer in '93). Thanks. Brooks John Hairell |
![]() "John Hairell" wrote in message news ![]() On Wed, 10 Mar 2004 13:30:44 -0500, "Kevin Brooks" wrote: John, you might be able to answer a question I have regarding autorotations. My late brother experienced exactly one serious mishap in a helo (outside getting shot down once in Vietnam and having various small arms rounds zing through the cabin on other occasions). It involved an autorotation in a Schweizer 300C (read as Hughes 300/TH-55). He was checking out a cop from the (unnamed big city) police department, which had recently purchased a couple of 300C's for law enforcement work. Apparently the cop, who was also a part-time ARNG Cobra pilot, had come through flight school during the post-TH-55 days. During the autorotation, the guy apparently treated the 300C like it was a Cobra, which I gather is a bad thing to do, and when my brother tried to take back over the guy froze up and fought the controls--resulting in a hard landing and rolling the aircraft onto its side (he compounded that by stomping all over my brother, who was left on the lower side, in his haste to depart the now-stationary aircraft). Any idea what the guy could have done that led to my brother trying to take control? And FYI--the accident investigation cleared my brother in the incident, so I gather that his side of the story was the way it happened. Kevin, I've been talking about this with a well-know Vietnam-era cav pilot and he says that there's not a whole lot of difference between a TH-55/Hughes 300 "Mattel Messerschmitt" as far as autorotation. The Cobra flares higher and longer, and TH-55s level the skids prior to touchdown. He says it sounds like a late "recovery" to him. If you have a date and location we could dig out the NTSB accident report and see what the official cause was. John Hairell Your message got me to scrounging on my own and I found the NTSB report (20001211X16230 --not easy to find, as the NTSB for some reason labled the aircraft as a Hughes 269, instead of Schweizer 300C, which they use elsewhere in their database). Looks like they dinged my brother for supervisory failures (i.e., failing to sufficiently prepare for "NO TRANSFER OF CONTROL PROCEDURES HAD BEEN ESTABLISHED BEFORE TAKEOFF", but noted the copilot as a cause for "improper" touchdown. Interestingly, they also dinged Larry for failing to take over the aircraft "in a timely manner", but as I recall it he indicated the problem arose rather abruptly as they were approaching touchdown, and when he tried to take over the copilot refused to relinquish control (the report indicates *both* were on the controls at impact). Beyond the data in the report, all I can remember him indicating was that the investigator assured him he nothing to worry about in terms of any regulatory/punitive actions. I was surprised to note that the incident occured only about seven months before he passed away--I had thought it a bit earlier. Thanks for the heads up. Brooks |
On Fri, 12 Mar 2004 16:01:35 -0500, "Kevin Brooks"
wrote: Your message got me to scrounging on my own and I found the NTSB report (20001211X16230 --not easy to find, as the NTSB for some reason labled the aircraft as a Hughes 269, instead of Schweizer 300C, which they use elsewhere in their database). Looks like they dinged my brother for supervisory failures (i.e., failing to sufficiently prepare for "NO TRANSFER OF CONTROL PROCEDURES HAD BEEN ESTABLISHED BEFORE TAKEOFF", but noted the copilot as a cause for "improper" touchdown. Interestingly, they also dinged Larry for failing to take over the aircraft "in a timely manner", but as I recall it he indicated the problem arose rather abruptly as they were approaching touchdown, and when he tried to take over the copilot refused to relinquish control (the report indicates *both* were on the controls at impact). Beyond the data in the report, all I can remember him indicating was that the investigator assured him he nothing to worry about in terms of any regulatory/punitive actions. I was surprised to note that the incident occured only about seven months before he passed away--I had thought it a bit earlier. Yeah, the NTSB database needs some cleaning up. The FAA civil registry database is even worse - they've got many, many examples of the same aircraft type listed under multiple model numbers. And they should stick with the manufacturer's model number versus the sales name, which may not be the same, for example there's no such thing as a Hughes model 500C or 500D or 500E (it's a model 369HS/HC/HM/D/E or 530 variant). OH-6As are model 369A but they have some listed as 500s. Doing civil registry searches I have to look under 12 different model types to dig them all out, when I should have to look at the most four or five. Some of the model numbers have typos in them, so you have to also think of all of the possible errors they could have made. I keep running into N-numbers that should belong to a known model type but when I look them up I find they have been mis-filed. Unless you know the specific N-number of that aircraft you would never find it using a model search. John Hairell |
![]() John‰] wrote: much interesting info snipped Controlled Descent ? The next question you are probably asking yourself is: "Does the pilot retain control of the helicopter?" The answer is yes. The pilot will still have complete control of his descent and his flight controls. The majority of helicopters are designed with a hydraulic pump mounted on the main transmission. Is this how the anti-torque rotor is driven in the event of powerplant failure? |
Junkers Ju86R-1 high altitude recce aircraft | Dave Eadsforth | Military Aviation | 2 | January 24th 04 10:36 PM |
High altitude Helicopter work | Allen | Military Aviation | 34 | December 5th 03 08:17 AM |
GPS Altitude with WAAS | Phil Verghese | Instrument Flight Rules | 42 | October 5th 03 12:39 AM |
Low and high altitude airways | David Megginson | Instrument Flight Rules | 7 | September 9th 03 01:18 AM |
High Altitude operations (Turbo charge???) | Andre | Home Built | 68 | July 11th 03 11:59 PM |
