On 5/3/2012 11:03 AM, JohnDeRosa wrote:
Connectors - I have really fallen in love with PowerPole connectors. They are robust, don't disconnect inadvertantly, and are infinitely variable as to configuration or the number of connections. See my report at http://chicagolandglidercouncil.com/...etterNov11.pdf. See instructions at http://www.wb3w.net/powerpoleinst.htm. I agree. In the ham radio community, Anderson Powerpoles have become the defacto standard power connectors - and for good reasons. The down side is that in order to do a *really* good job, you need a good crimping tool - about US$50. You can do a reasonable job with less expensive crimpers. See also http://www.youtube.com/watch?v=5PBBd-ssoeY Tony V. LS6-b "6N" - W1DYS |
The problem is not finding the right connectors, but more figuring out if I'm
going to drill in my wingtip etc. I am lucky enough to get Lemo or Souriau connectors with the appropriate tools. These are mil-specced connectors, so have all the features I need (pulling the wire will only tension the mantle, good locking mechanism, etc). For example: how to connect a chassis-type Souriau connector to the wingtip? The chassis-connector has 2 holes. Should I screw them to the wingtip with screws that require no drilling? Or use blind rivets? Roel |
Gap Tape? Electrical OK? | ContestID67 | Soaring | 10 | May 2nd 06 07:37 AM |
Ignition Exciter Wiring | Juan E Jimenez | Home Built | 0 | August 31st 03 06:03 AM |
Ignition Exciter Wiring | Juan E Jimenez | Aviation Marketplace | 0 | August 31st 03 06:03 AM |
Ignition Exciter Wiring | Juan E Jimenez | General Aviation | 0 | August 31st 03 06:03 AM |
Ignition Exciter Wiring | Juan E Jimenez | Owning | 0 | August 31st 03 06:03 AM |
