Rudder Cable Systems Used in Modern Sailplanes
Old May 16th 12, 05:09 PM posted to rec.aviation.soaring
Bart[_4_]
Default Rudder Cable Systems Used in Modern Sailplanes
On May 16, 2:10*am, GC wrote:
Also, with great respect to Bob K and his experience, I'm not convinced
airflow will sufficiently straighten a rudder with a broken cable. *Even
in the best case there will be residual deflection where the airflow
balances the other spring. *This could be quite large.
Isn't that something that can be easily (and safely) verified? In many
gliders, rudder cables are accessible in the cockpit. Take a high tow,
grab one cable and pull it. This simulates broken spring or broken
cable on one side. If the glider becomes uncontrollable, just release
the cable.
Bart
Russian defense minister Sergei Ivanov confirms the sale of modern TOR-M1 anti-aircraft missile systems to Iran AirRaid Naval Aviation 1 January 16th 07 05:06 PM
Rudder cable slots Ernest Christley Home Built 5 July 1st 06 04:29 AM
Can anyone help, PLEASE - searching for zip-cord (aka: mono-cord, speaker wire, shooting wire, dbl hookup, rainbow cable, ribbon cable) Striker Cat General Aviation 0 October 12th 04 05:11 PM
rudder cable question Bob Loer Home Built 7 November 26th 03 08:34 AM
Rudder cable - was The Little Wheel in Back BD5ER Home Built 9 September 11th 03 04:14 PM
