PowerFlarm @ Mifflin
Old May 24th 12, 02:16 PM posted to rec.aviation.soaring
Evan Ludeman[_4_]
Default PowerFlarm @ Mifflin
On May 23, 11:10*am, Karl Kunz wrote:
Paul, thanks for some good info. One more question, does the brick use the same stub antennas as the portable? If not, can the brick antennas be used with the portable (i.e. remotely)
-karl
The brick has three antennas: a GPS puck, a TXP/ADS-B 1090 receiving
antenna (dipole) and a Flarm TX/RX antenna (dipole). The two dipoles
are physically similar, but have different connectors. Mounting, as
others have emphasized, is key to performance. I see flarm traffic
out to about 6 miles front and sides, 2 miles or so at 6 o'clock. I
have my antennas mounted using plastic stock cut from cheap Walmart
magazine organizers which is adequate for the moment. At some point
I'm sure I''ll be inspired to do something a little more robust.
Evan Ludeman / T8
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
Day cancelled at Mifflin (again) Frank Paynter[_2_] Soaring 0 May 24th 11 07:36 PM
Day cancelled at Mifflin Frank Paynter[_2_] Soaring 0 May 23rd 11 05:30 PM
Day 2 at Mifflin Frank Paynter[_2_] Soaring 0 May 22nd 11 11:07 PM
Pre-contest day at Mifflin Frank Paynter[_2_] Soaring 0 May 21st 11 12:48 AM
