On 6/8/2012 10:01 AM, bumper wrote:
Bob, I did a post on this earlier. I use my PowerFlarm portable in both my glider and Husky tow plane. I installed a plug-in super bright LED that attaches to the side of the PF with Velcro. It plugs into the audio out and the coaxial power jack on the PF, so is easy to remove. It uses the PF audio out to bias a transistor driver for the alarm LED - - bright enough to get your attention even in full sunlight. One can also wire the PF audio out directly to the headset jack in the aircraft. Even though the PF has menu adjustable audio out level, depending on audio levels desired, you may need to install a series dropping resistor of 50 ohms or more to lower the audio to a reasonable level. An alternative for towplanes with an intercom (separate box or built into the radio) is to have the PowerFlarm audio output connect to one of the intercom inputs. That will bring it to the pilot's headset without any conflicts. Some newer radios, like the MGL Avionics V6 I just installed, also have dedicated audio inputs for warning devices like the PowerFlarm. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) |
On Friday, June 8, 2012 11:32:59 AM UTC-7, Eric Greenwell wrote:
On 6/8/2012 10:01 AM, bumper wrote: Bob, I did a post on this earlier. I use my PowerFlarm portable in both my glider and Husky tow plane. I installed a plug-in super bright LED that attaches to the side of the PF with Velcro. It plugs into the audio out and the coaxial power jack on the PF, so is easy to remove. It uses the PF audio out to bias a transistor driver for the alarm LED - - bright enough to get your attention even in full sunlight. One can also wire the PF audio out directly to the headset jack in the aircraft. Even though the PF has menu adjustable audio out level, depending on audio levels desired, you may need to install a series dropping resistor of 50 ohms or more to lower the audio to a reasonable level. An alternative for towplanes with an intercom (separate box or built into the radio) is to have the PowerFlarm audio output connect to one of the intercom inputs. That will bring it to the pilot's headset without any conflicts. Some newer radios, like the MGL Avionics V6 I just installed, also have dedicated audio inputs for warning devices like the PowerFlarm. -- Eric Greenwell - Washington State, USA (change ".netto" to ".us" to email me) Many newer aviation headsets have a direct audio input designed for iPods/MP3 players or cell phones. e.g. The Clarity Alofts I use in the ASH-26E do.... Darryl |
CAV 11 Audio Vario/no Audio ideas? (Cambridge) | Gregg Leslie[_2_] | Soaring | 3 | June 4th 11 12:08 AM |
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? | Bret | Soaring | 0 | August 30th 10 04:24 AM |
Audio Highlights while owning N1943L - Audio only with text | [email protected] | Owning | 0 | May 1st 10 03:07 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
