On Jun 8, 2:53*pm, Eric Greenwell wrote:
On 6/8/2012 1:45 PM, Andy wrote: I ignored it because I couldn't find a full specification or manual for the brick; however, I'd be surprised if it doesn't have the audio output port, as it would seem to be even more useful on the brick than on the portable. Perhaps the audio port is available on a remote display? Just guessing, since I did not find the specifications I reviewed the brick preliminary user manual. It makes no mention of an audio output port. There is no audio output connector shown in the pictures and no mention of audio output in any of the connector pin outs. I couldn't even find any mention of audio alarms. The manual is preliminary though. It is my understanding that the alarm audio is provided by the rectangular display that is an option with the brick. If that's true then the audio alert is probably encoded in the serial data output(s) of the brick. I am not aware that this display provides an audio jack. Andy |
I highlighted that already in the original thread when the Brick
manuals became available: https://groups.google.com/group/rec....8775b7bdd8ba1b It might have to do with the system architecture, where the brick does the calculations, but the display needs to take care of the presentation of the data to the user, visual as well as audio. On the other hand, the Garrecht Brick TRX-1500 does have an audio output (and an additional serial interface) in the D-Sub15HD connector. http://garrecht.com/index.php/en/ads-b/trx-1500. It is indeed a bummer that the PowerFlarm brick does not have this feature. As Eric said, most newer radios have great features to input audio from other sources (and mix/switch it properly) Now, I still have some hope: In the current published PowerFlarm Brick documentation, on the DB9 connector, pins 1, 4 and 6 have not been described. I am keeping my fingers crossed. Hopefully someone from the Flarm team can shed a light. 3U |
"Hopefully someone from the Flarm team can shed a light."
Yeah, that would be a welcome and refreshing change! |
CAV 11 Audio Vario/no Audio ideas? (Cambridge) | Gregg Leslie[_2_] | Soaring | 3 | June 4th 11 12:08 AM |
Schematics for Cambridge CVS50 vario and audio unit? Or anyoneselling a similar working audio variometer? | Bret | Soaring | 0 | August 30th 10 04:24 AM |
Audio Highlights while owning N1943L - Audio only with text | [email protected] | Owning | 0 | May 1st 10 03:07 AM |
Take-upReels on Towplanes | Nyal Williams | Soaring | 9 | April 21st 04 12:39 AM |
Helicopters and Towplanes | Burt Compton | Soaring | 6 | September 11th 03 05:21 PM |
