AR 4201 low volume on receiving side
Old June 22nd 12, 04:13 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default AR 4201 low volume on receiving side
On 6/21/2012 4:34 PM, T wrote:
On Jun 20, 6:20 pm, Bill D wrote:
On Jun 20, 6:46 pm, T wrote:
You raise your voice naturally because you are in a noisy
environment. AFAIK, all 'airplanes' are powered.
Really? With proper hearing protection, ear plugs and flying helmets,
my ears and mouth do not know I'm in a noisy environment. With 15+ hr
missions, I've never come back with a soar throat from raising my
voice.
And the sidetone is adjusted so you hear your voice in the headphones at
a decent level, which keeps you from shouting.
email me)
Old June 22nd 12, 04:58 AM posted to rec.aviation.soaring
Bill D
environment. *AFAIK, all 'airplanes' are powered.
voice.
email me)
OK, just put a 'scope on it and check the modulation level. I'll bet
that it is way to low for normal voice in a glider but about right for
an airplane.
Old June 22nd 12, 06:41 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
voice.
email me)
an airplane.
The airplane pilots I hear don't sound like they are shouting, but are
just using a normal speaking voice. Even low cost headsets have
noise-canceling mikes and good sound isolation in the ear cups, so I
would not expect pilots using them to have to speak more loudly than a
glider pilot.
email me)
HP310 and hx4705 - side by side, first impression Tuno Soaring 8 February 23rd 09 07:30 PM
HP310 and hx4705 - side by side, first impression Darryl Ramm Soaring 0 February 22nd 09 02:42 AM
Saturn V S-IC (first) stage are placed side by side prior to commencement of the mating of the two stages 6416485.jpg [email protected] Aviation Photos 0 April 12th 07 01:28 AM
For Mitchell Holman, if you want them... - F-15 & F-16 on pedestals WPAFB side by side.JPG (1/1) Blue Oval/Dan Edwards Aviation Photos 4 January 19th 07 01:19 AM
Is That a Resistor Wired Between the Hot Side and the Switch Side of the Solenoid? jls Owning 3 April 11th 04 04:55 PM
