On Monday, July 16, 2012 2:42:49 PM UTC-4, Tim Taylor wrote:
> One *good solution used on a jantar is a jack to lift a motorcycle.. > Best after market solution! > S6 1. Too heavy 2. Too bulky 3. Thrust bearings tend to break So no it is not the best after market solution. Been there, tried that. I'll second that. I've now rebuilt the original scissors jack for my 1999 Komet trailer 3 times; the outer thrust bearing has failed yet again. I still kick myself for returning the screw-jack version that they accidentally shipped when I first bought the trailer. Simple, robust, relatively light, and works as well at zero height as it does at full extension. I looked at the motorcycle jack (Big Red or somesuch) at my local motorcycle dealer. The thing weighs nearly 40 pounds! And, there wasn't any reason to expect it to last any longer under the repeated cycles of use in the grass and gravel that's typical at our airport. In the meantime, the UPS truck should be arriving at my house tomorrow with the pieces to make an over-center lever job. If I could just come up with a slightly more elegant way to store the long handle, I would be completely happy! |
At 13:14 17 July 2012, Papa3 wrote:
On Monday, July 16, 2012 2:42:49 PM UTC-4, Tim Taylor wrote: One =A0good solution used on a jantar is a jack to lift a motorcycle= .. Best after market solution! S6 =20 1. Too heavy 2. Too bulky 3. Thrust bearings tend to break =20 So no it is not the best after market solution. Been there, tried that. I'll second that. I've now rebuilt the original scissors jack for my 1999 = Komet trailer 3 times; the outer thrust bearing has failed yet again. I = still kick myself for returning the screw-jack version that they accidental= ly shipped when I first bought the trailer. Simple, robust, relatively lig= ht, and works as well at zero height as it does at full extension. =20 I looked at the motorcycle jack (Big Red or somesuch) at my local motorcycl= e dealer. The thing weighs nearly 40 pounds! And, there wasn't any reas= on to expect it to last any longer under the repeated cycles of use in the = grass and gravel that's typical at our airport.=20 In the meantime, the UPS truck should be arriving at my house tomorrow with= the pieces to make an over-center lever job. If I could just come up wit= h a slightly more elegant way to store the long handle, I would be complete= ly happy!=20 a telescoping handle will be shorter and easier to store. should work |
Cobra trailer hydraulic jack refurb? | Frank[_1_] | Soaring | 5 | March 12th 09 11:50 PM |
Komet Trailer Ramp Jack - NO SCREWS | [email protected] | Soaring | 7 | April 23rd 08 05:39 AM |
Ramp jack for Komet Trailer | [email protected] | Soaring | 8 | April 2nd 08 05:37 PM |
Double scissor jack for trailer ramp? | Bullwinkle | Soaring | 15 | January 18th 06 05:18 PM |
Aluminum Extrusion for trailer ramp (USA) | ttaylor at cc.usu.edu | Soaring | 5 | June 28th 05 04:19 PM |
