Hi,
This is an update to the note below. Dave Nadler reports that the USB adapter in the link below is said to work with the SN10. I have ordered one to test. I'll update my web site after I test it. http://www.amazon.com/dp/B003N9TYW0/...C1_cs_sce_dp_2 Also, I found the post below from Walt Rogers with links to USB adapters that he says work with his SN10. Best Regards, Paul Remde Cumulus Soaring, Inc. __________________________________________________ ________ FYI, recently I upgraded my notebook to Windows 7 64bit. I've found a good reliable USB serial convertor that works "out of the box" on Windows 7 even the 64 bit version. USB to Serial Adapter - Mini PRO - $27.50 http://www.usconverters.com/index.ph...ducts _id=244 Another one almost identical but with a cable USB to Serial Adapter - Professional - $34.95 http://www.usconverters.com/index.ph...ducts _id=325 This convertor has a very well written device driver that is maintained and kept up to date. My older Belkin convertor stopped working when I changed to Windows 7 64bit. Also, it wouldn't work on my Volkslogger, so I had to use a PCMIA serial card with WinXP (the PCMIA card doesn't work anymore in Windows 7 64bit). These USB serial convertors from usconverters.com work just fine on everything I need (Volkslogger and SN10B software/waypoints loading). With the Volkslogger, download used to be extremely slow. Now, I've found a driver setting on the Mini PRO which speeds up the download! It was a "Latency Timer" (msec) changed from 16 to 1. So... if you're having problems with USB to RS232 convertors, give these a try. Walt Rogers, WX __________________________________________________ __________________ "Paul Remde" wrote in message ... Hi, I can't get the Keyspan USA-19HS USB to serial adapter to work with an SN10. It connects, but waypoint transfer attempts failed. I am using Windows 7 64-bit with the appropriate drivers from Keyspan. The Keyspan adapter works great for me with all other soaring instruments - just not the SN10. The same was true for me with Windows Vista 32-bit. In the past I had used and recommended the Belkin F5U409 USB adapter for use with ILEC SN10 units. It worked great for me with Windows Vista 32-bit. But Belkin doesn't provide drivers for Windows 7 (32-bit or 64-bit). Does anyone have any suggestions for connecting a Windows 7 64-bit machine to an SN10? Of course, the ILEC SN10 USB adapter makes this all unnecessary, but I get this question from customers often and want to be able to recommend a solution for them that costs less than the very nice, but expensive ILEC option. Best Regards, Paul Remde Cumulus Soaring, Inc. _________________________________________ "YourNameHere" wrote in message ... After several days trying to get Windows 7 64 bit to connect to an SN10 via a USB to Serial adapter (Dynex), here is what finally worked great. Posting this so folks don't have to go through discovery. USB to Serial Adapter made by Keyspan (model USA-19HS) with Keyspan Windows 7 driver. SN10B with firmware 2.36 Windows 7 Home Premium (64bit) |
USB Serial Converters - Reliable one for SN10 and Volkslogger | WaltWX[_2_] | Soaring | 15 | June 22nd 12 07:32 AM |
Documentation update for ILEC SN10/SN10B USB adapter | Dave Nadler | Soaring | 0 | February 22nd 10 04:15 PM |
Bug in ILEC SN10 USB adapter fixed 3-Feb-2010 | Dave Nadler | Soaring | 2 | February 20th 10 03:41 AM |
USB to RS-232 Serial Adapter Advice | Paul Remde | Soaring | 36 | March 6th 09 07:40 PM |
USB-to-serial converters that work (especially with ILEC SN10) ? | [email protected] | Soaring | 35 | May 27th 05 09:58 AM |
