I have two little 'mouses' mounted under my panel cover. These have two screw holes on opposite sides for attaching. Thru these holes I would run plastic locking wire ties and around the top tubular panel frame ( S-H Discus ) suspending them in between the frame tubes. They (GPSs) are suspended a few inches apart just underneath the panel cover and have never failed to provide a signal. No glue or tape and easily to removed and replace when instrument work is required.
R |
Pegasus panel cover | Charles Kotila | Soaring | 0 | June 30th 12 11:07 PM |
PowerFlarm mounting question, and an idea for mounting devices | brianDG303[_2_] | Soaring | 2 | October 23rd 11 06:51 PM |
PIREP Needed - Aircraft Door Seals Instrument Panel cover | Mike Spera | Owning | 2 | June 24th 06 05:02 PM |
Antennas | Terry | Home Built | 3 | April 24th 05 06:42 PM |
Antennas | Terry | Home Built | 3 | April 22nd 05 03:14 AM |
