Mounting GPS antennas under panel cover
Old July 23rd 12, 05:28 PM posted to rec.aviation.soaring
brianDG303[_2_]
Default Mounting GPS antennas under panel cover
I assume that if you have a DG with the very dull grey pod that the pod is carbon and that this won't work?
Brian
Old July 23rd 12, 05:52 PM posted to rec.aviation.soaring
JohnDeRosa
A couple of comments and medium-baked ideas;
1) The adhesive on 3M's Dual Lock is especially good, unlike most
velcro you find in stores. Dual Lock *should* stay stuck even in a
hot environment. You might troll the 3M site for temperature specs
(they mention aerospace).
2) I bolted my GPS antenna under the glare screen (which is not
mounted to the canopy). To allow for break away in your situation you
could use nylon bolts instead of metal bolts. To really make sure
they break away, you could remove some concentric material (cut a
groove) around the bolt near the head. Removing concentric material
is what is done for break away mounting of, for example, runway
lights.
3) Double stick tape? That should break away. But might have the
same temperature issues. Again, stick with 3M branded.
Good luck, John
Old July 23rd 12, 06:17 PM posted to rec.aviation.soaring
brianDG303[_2_]
Good luck, John
3M VHB tape has published specifications, and most of them are rated at 90 lbs/sq. inch tensile, so even at elevated temps. you would probably be OK if you maxed out the area. The fail temperatures are in the 200F to 250F range. Assuming Dual-Lock uses a similar adhesive seems like you would be fine.
Brian
Pegasus panel cover Charles Kotila Soaring 0 June 30th 12 11:07 PM
PowerFlarm mounting question, and an idea for mounting devices brianDG303[_2_] Soaring 2 October 23rd 11 06:51 PM
PIREP Needed - Aircraft Door Seals Instrument Panel cover Mike Spera Owning 2 June 24th 06 05:02 PM
Antennas Terry Home Built 3 April 24th 05 06:42 PM
Antennas Terry Home Built 3 April 22nd 05 03:14 AM
