Shortening PowerFLARM Brick Antenna and GPS cables
Old September 17th 12, 10:01 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default Shortening PowerFLARM Brick Antenna and GPS cables
On 9/17/2012 5:12 AM, Jim wrote:
The GPS antenna cable doesn't carry high frequency RF, so tidiness
is
the only value in reducing the length.
Eric, so why do we need a GPS antenna wire if the signal from the
satellite magically gets to the receiver without the RF signal first
going through the antenna wire :=P I'm fairly sure that the GPS
antennas are "active" antennas getting phantom dc power from the
receiver but I thought they only had an amplifier; are you sure they
also have a local oscillator & mixer to convert the RF to an IF (I
guess like an LNB)? Amazing for such a cheap device.
A lot of antenna "pucks" are not just GPS antennas, but GPS receivers.
What comes out of the cable is data, not RF. That's not true of every
GPS "puck", of course, but I think it's true of the PF units. Even if
it's the active antenna type you mention, because the output is
amplified and a lower frequency than the raw GPS signals, the cable loss
would be an issue. So, reduce the cable length for tidiness, not signal
strength.
The dipole antennas are passive, so shortening their cables might
improve their output. Without knowing the cable type, I can't say how
much, but I'd guess the antenna designers chose cable that did not have
significant losses for the length provided.
email me)
- "Transponders in Sailplanes - Feb/2010" also ADS-B, PCAS, Flarm
http://tinyurl.com/yb3xywl
Old September 17th 12, 11:34 PM posted to rec.aviation.soaring
Dave Nadler
Wrong.
Wrong. It's an antenna, NOT a receiver.
Even if it's the active antenna type you mention, because the output is
Wrong.
Please don't speculate where people may take it seriously,
even on R.A.S...
Thanks,
Best Regards, Dave
Old September 18th 12, 04:53 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Wrong.
Wrong.
even on R.A.S...
Thanks,
Best Regards, Dave
Well, humph! It wasn't speculation, it was ignorance!
So, are most of the GPS pucks are passive antennas, or are they
amplified but with no frequency conversion? And is it useful to shorten
the cable to increase signal strength?
email me)
Old September 18th 12, 07:31 AM posted to rec.aviation.soaring
Darryl Ramm
Outboard antennas are amplified RF, no local mixer/downconversion.
Darryl
Darryl Ramm
Darryl
Old September 18th 12, 07:34 AM posted to rec.aviation.soaring
Darryl Ramm
The only ones "outboard receivers" are things like USB connected pucks, where everything lives in the puck.
Darryl
Video of Powerflarm brick in action Ramy Soaring 7 September 1st 12 12:51 AM
Powerflarm Brick feedback Ramy Soaring 7 August 10th 12 01:02 AM
PowerFLARM Brick and PowerFLARM Remote Display Manuals Available Paul Remde Soaring 30 May 25th 12 11:58 PM
PowerFLARM 'brick' progress? Frank Paynter[_2_] Soaring 5 November 13th 11 07:28 PM
Display for PowerFLARM brick Andy[_1_] Soaring 4 May 10th 11 02:32 PM
