Which sustainer system would you chose for your sailplane?
Old September 24th 12, 11:53 PM posted to rec.aviation.soaring
Greg Arnold
Default Which sustainer system would you chose for your sailplane?
On 9/24/2012 3:39 PM, Renny wrote:
Here's the URL for a PDF brochure that was handed out at the 2012 Reno Convention on the FES. Hopefully, it will answer some of the many questions that are out there!
http://www.front-electric-sustainer....katalog_V2.pdf
Thanks - Renny
Interesting that the Silent has more battery capacity than the LAK. I
wonder if the LAK can be modified to take the larger battery capacity.
Old September 25th 12, 12:23 AM posted to rec.aviation.soaring
Renny[_2_]
Thanks - Renny
Greg,
My LAK-17B FES does have two batteries with 14 cells...so it does have the following:
"2 x 14S LiPo, 20 kW continuous power"
The earlier installations had the 12 cell LiPo batteries, but it was upped to 14 cells for the newer 17B installations. Each battery is 58 volts, so when fully charged it starts off at 116 volts. FYI, I did write an article for Soaring on the LAK-17B FES and I am hopeful that it will be published soon.
Thx - Renny
Old September 25th 12, 12:38 AM posted to rec.aviation.soaring
Greg Arnold
Greg,
Thx - Renny
Renny:
What type of climb rate, total climb, and range are you seeing?
Old September 25th 12, 03:31 AM posted to rec.aviation.soaring
Renny[_2_]
Greg,
Thx - Renny
Renny:
I have had limited experience running the FES on the LAK-17B FES as this is my first season using the FES and the ship was also away for several weeks this summer at the WGC in Uvalde. I am also very fortunate to fly out of Moriarty, and with our excellent conditions, I have not had to use it (thus far)out of necessity.
So, I have no data on endurance and range, but in conducting some local (unscientific) testing, I have been able to climb (dry) on a hot day (over 95 deg F on the ground) at over 200 fpm at altitudes of 8,500 to 9,000 feet MSL in the 18m configuration. FYI, the Moriarty airport is at 6,200 feet. Hopefully, you will see additional and more scientific data as Idaflieg testing was conducted in August and results are expected this winter.
Thx - Renny
Old September 25th 12, 04:04 AM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Next year, you should press a little harder, and get some value out the
FES. Then, you will discover it can set you free to explore more than
you imagine now!
email me)
Old September 25th 12, 04:14 AM posted to rec.aviation.soaring
Renny[_2_]
you imagine now!
email me)
Eric,
Indeed...That is definitely the plan!
Thx - Renny
Old September 29th 12, 01:00 AM posted to rec.aviation.soaring
On Monday, September 24, 2012 4:23:59 PM UTC-7, Renny wrote:
On Monday, September 24, 2012 4:53:12 PM UTC-6, Greg Arnold wrote: On 9/24/2012 3:39 PM, Renny wrote: Here's the URL for a PDF brochure that was handed out at the 2012 Reno Convention on the FES. Hopefully,
Renny, so you're running about 170 Amps or so. Your motor and esc need some cooling, so how is that accomplished? And then you must have a way to automatically override throttle if lipos approach 70 to 80% drained?
Old September 29th 12, 01:17 AM posted to rec.aviation.soaring
Renny[_2_]
Motor cooling is handled via a small electric fan forward of the rudder pedals, an air vent in the nose cone that allows outside air to help cool the motor (and the cockpit), and 3 electric fans on the shelf behind the pilot's seat to cool the controller. When the batteries get low, warnings go off on the FCU, and I would then throttle back and turn off the FES. There is no automatic shutdown of the FES which allows the pilot to keep the FES running if there is an emergency situation. Thx - Renny
Old September 29th 12, 07:41 AM posted to rec.aviation.soaring
Dne sobota, 29. september 2012 02:17:14 UTC+2 je oseba Renny napisala:
On our latest instalations, we manage to arrange cooling also without electric fan infront of pedals. Motor itself has bigger centrifugal ventilator at back side!
Regards, Luka
Old September 29th 12, 04:42 PM posted to rec.aviation.soaring
slbair
Regards, Luka
Luka,
It sounds like a number of incremental changes have been made to the FES system that have not yet been posted to your web site. Could you write a post detailing these changes and perhaps also let us know what's coming in the near future? Thanks,
SLB
Front Electric Sustainer Dan Marotta Soaring 28 January 31st 13 01:32 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Which Came First, the Santa Monica Airport, Or Those Who Chose To Build Their Homes Adjacent To It? Larry Dighera Piloting 16 May 7th 07 10:34 PM
BAF or CEF? I chose BAF. Paul Tomblin Instrument Flight Rules 0 October 23rd 04 04:33 PM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
