I believe the reason why the brick does not have an audio jack is that it only produces NMEA sentences which are processed by the display which produces the audio alerts.
Ramy |
On Sunday, October 14, 2012 11:54:47 AM UTC-7, Ramy wrote:
I believe the reason why the brick does not have an audio jack is that it only produces NMEA sentences which are processed by the display which produces the audio alerts. Ramy Understood. But they "could" add the additional circuitry and audio jack to the brick, as they "could" have built in a bright alert LED on the portable (to make it more viable in tow planes etc, without having to wire it into the headset audio). Neither change is likely as I doubt there's enough demand and they are working on other improvements. I also suggested to them that they provide a lower intensity back light on the portable for night flying (power plane). Lowest it goes now is 10%, which sounds just fine until you try flying with it at night! Lowest setting is still so bright it interfers with night vision.. If they don't fix that in a software revision I'll use some dark static cling plastic over the screen I guess. bumper |
Where are you Butterfly vario? | [email protected] | Soaring | 17 | May 25th 14 05:49 AM |
Butterfly iGlide | Reed von Gal | Soaring | 4 | May 2nd 12 06:00 PM |
New Butterfly Vario | Paul Remde | Soaring | 238 | February 20th 12 04:05 AM |
This Just In- Butterfly | [email protected] | Soaring | 6 | February 17th 12 09:00 PM |
Ipad compatible bluetooth GPS which has an external antennasocket and external pwr input? | macpacheco | Instrument Flight Rules | 1 | November 12th 11 03:32 PM |
