ASW-27b 23lb on tail. Dry no pilot.
Mosquito A 46lb on tail. Dry no pilot. |
1970 LS1-d
Empty 70.0 lbs (31.75Kg) With pilot on board, ready to fly: 48.0 lbs (21.77Kg) |
1978 Grob Twin Astir Serial Number 3075
Empty Tail: 113.5 Main: 818 On Wednesday, December 5, 2012 12:49:48 PM UTC-5, soartech wrote: All sailplane owners, Please reply with the weight on your tail wheel from your weight and balance sheet. I will calculate the average after a few days and post it and the range. Reply on this list or directly to me, either way is fine. Thanks. |
DG-1000 109 lbs without tail weights and empty cockpits
THANKS ALL for your helpful info.
I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? |
I just risk my back. The Speed Astir 'Dolly' is just a post on a
wheel. That's nice, because you can't accidentally take off with it on, but lifting that 90 lb tail and trying to fit the post into the hole in the underside of the fuselage can be challenging. The Janus uses a conventional dolly and has only 64 lbs on the tailwheel. Piece of cake. BTW, on the subject of weight and balance, just for your own knowledge you might want to run the numbers with your tail dolly ON. In the case of the Janus, the glider remains well within CG limits unless it is being flown solo by a person that is lighter than me, or any of my partners. On Dec 7, 1:32*pm, soartech wrote: THANKS ALL for your helpful info. I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? *I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? |
On Friday, December 7, 2012 4:32:41 PM UTC-5, soartech wrote:
Has anyone made a simple lever-lifted dolly arrangement? Of course: http://www.cobratrailer.com/catalog/...roducts_id=144 |
On Friday, December 7, 2012 5:33:52 PM UTC-5, Dave Nadler wrote:
Of course: http://www.cobratrailer.com/catalog/...roducts_id=144 PS: Tail weight of Antares 20E without pilot: 139 lbs. This feature means that with pilot, under full power, there is still adequate weight on steerable tail wheel to provide excellent directional control during initial take-off. But don't try to lift the tail ! |
On Fri, 7 Dec 2012 13:32:41 -0800 (PST), soartech
wrote: .... text deleted Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? I'd recommend Mark Mocho's combination tow dolly with integrated lift bar. http://www.mmfabrication.com/towbars.htm A very satisfied user. Bob |
On Friday, December 7, 2012 2:32:41 PM UTC-7, soartech wrote:
THANKS ALL for your helpful info. I was simply trying to determine if my glider had a typical tail wheel weight. The first time I tried to lift the tail to install a dolly I was dismayed to discover how heavy it is. All I had to compare it with is the club fleet of three SGS machines which all have very light tail weights. It seems as if the older gliders (Cherokee, 1-26, 1-34) are almost balanced on the wheel whereas the glass ships are quite heavy. Does this make them any trickier to land? I realize the flying balance is most likely different from wheel balance i.e CG and wheel are not co-located. The average of the single place tail weights without pilot aboard is 66 lbs. and mine is 72 lbs. so I am right in the ballpark. Has anyone made a simple lever-lifted dolly arrangement? Or do you risk your back with the poor lifting position that the tail boom presents? I agree with Bob's comment about Mark Mocho's tow bar and tail boom lifter. It works very well and there are at least 30 or 40 satisfied users at Moriarty and there are many other users around the US! His website is: www.mmfabrication.com |
ASK-21 Weight and Balance | Carl Baxter | Soaring | 4 | June 2nd 11 02:57 PM |
PA-32 Weight and Balance | John Doe | Owning | 14 | May 23rd 06 01:03 AM |
L23 weight and balance | Tony Verhulst | Soaring | 5 | December 31st 05 01:54 AM |
Weight and Balance | Dale Larsen | Home Built | 2 | June 23rd 04 05:11 PM |
Weight and Balance | JP | Piloting | 2 | January 13th 04 10:54 AM |
