tail boom repair
Old December 22nd 12, 02:29 PM posted to rec.aviation.soaring
JJ Sinclair[_2_]
Default tail boom repair
On Friday, December 21, 2012 6:31:48 PM UTC-8, Brad wrote:
On Dec 21, 2:18*pm, CTEX wrote:
Thanks all. Your comments are a great help. And reassuring, too.
What I gather is that one should pay attention, but not go overboard on the subject. The point that these ships are essentially hand-make was something I hadn't considered, and it's helpful to keep that in mind.
Have Bob make you an HP-24 from scratch. You can even make your own
tail boom.
Brad
Tetra-15
N599GK
I would get the exact repair location from 337 or log entry and inspect that area closely. Use a long straight edge like a 48" level, the top, bottom and both sides should be dead straight. Tram the wings using a 50' steel tape. Measure from a common point on each wing (say the outboard aileron cut-out to the probe mount on the vertical fin. These readings should be equal, but don't get excited if the differ a tad, 1/4" is great, 1/2" about average and 1" poor (I have seen 1" difference on a new ship straight from the factory). The tram can be easily adjusted on some ships, LS and Genesis by moving the aft lift fitting out on one side and in on the other, start with 1/4 turn. On other ships this can be done with thin shims under the lift fittings..............excess slop in the main wing pins can be removed by doing this also.
Cheers,
JJ
Tail Wheels & Tail Booms snapp'n POPS Soaring 12 November 24th 11 02:00 AM
Tail Wheels & Tail Booms snapp'n db_sonic[_2_] Soaring 0 November 18th 11 08:35 PM
shuttle landing BOOM BOOM muff528 Piloting 0 March 27th 08 12:38 AM
Boom Mic - Just Mic Gary G Piloting 5 November 4th 05 03:53 PM
FS: Blanik L-13 Tail Skid & Tail Wheel Assembly Tim Hanke Soaring 0 February 8th 05 01:34 PM
