Replacing the MKIV yaw string - tips
Old January 1st 13, 04:11 AM posted to rec.aviation.soaring
bumper[_4_]
Default Replacing the MKIV yaw string - tips
On Monday, December 31, 2012 6:17:28 PM UTC-8, Jim Britton wrote:
I haven't been following this "thread" (pun intended) too closely so
forgive me if this has already been covered, but I am wondering if you have
thought of supplying left-handed MKIV's sometime soon. Us lefties have
enough barriers to overcome as it is - maybe if we had one less thing to
worry about...
Jim,
No offense, quit whining . . . have you considered Lefty Aversion Therapy?
We used to have a "don't ask don't tell" policy here at Bumper Soaring (or BS for short). Under intense political pressure, we had to end that. We still do our best to force all MKIV's from the same mold, ambidextrous and "straight". Unfortunately, we've noted a few with left leaning tendancies, some mostly go to the right, and nearly all, if given half an opportunity, will quite happily go both ways.
Yes, it's a source of embarrasement for us and for some MKIV owners. You may even notice in YouTube videos that many of these same owners will carefully edit out any shots where their MKIV is, um, wildly playing the field so to speak.
bumper
Old January 1st 13, 04:49 AM posted to rec.aviation.soaring
Tony V
worry about...
Jim,
How typical. It's always OUR problem. We've learned to live in a right
handed world. Is it really to much to ask for you to consider our
plight? You're probably against lefties marrying each other too.
Tony
Old January 1st 13, 05:56 AM posted to rec.aviation.soaring
bumper[_4_]
Tony
I had no idea what you are going though. A quick search found http://www.cracked.com/article_19808...-you-life.html
Do you fling cats at passers by? Should lefties be allowed to marry at all?
bumper
Old January 1st 13, 07:24 AM posted to rec.aviation.soaring
xcnick
Hi bumper, I am the Schweizer driver at the airport. With great interest I read the many sophisticated suggestions, but I fear they miss the most basic improvement needed. Your instrument gets right up in the pilots face with constant criticism. I get enough of that at home.
This is not all tongue in cheek. You may have noticed I have no instruments for just this reason. However as you are the most innovative builder perhaps you could come up with something with positive reinforcement. I am thinking pneumatic. ;-)
Old January 1st 13, 08:10 AM posted to rec.aviation.soaring
bumper[_4_]
xcnick,
I'm sure it can be done pneumatically, and fairly simply too. Something like two ports, one on each side of a forward facing vane, the port openings lateral to the ship's axis to avoid ram air. With no yaw, delta-p on ports is equal. With any yaw, delta-p increases.
Display could be analog, digital, or audio.
However, this yaw indicator would violate the KISS rule. More complexity for little or no gain in functionality over a yaw string.
It's also done with a slip or skid bank indicator ball, used in powe planes where prop wash precludes the use of a yaw string. http://www.aircraftspruce.com/pages/...nk_indicat.php
Though I think a yaw string is more sensitive than most ball indicators I've flown with - - plus you don't have to look at the panel to read the yaw string.
bumper
MKIV & QV increase bumper[_3_] Soaring 6 March 10th 10 01:22 AM
Emergency Landing in a COZY MKIV Marc J. Zeitlin Piloting 14 December 19th 06 03:25 AM
Replacing innertubes without replacing tires? Ben Jackson Owning 28 November 6th 06 04:54 PM
IFR Accelerated Training in my COZY MKIV Marc J. Zeitlin Instrument Flight Rules 1 April 13th 05 05:35 PM
Pocket PC Tips & Glide Navigator II Tips Paul Remde Soaring 0 December 14th 04 08:21 PM
