On Tue, 08 Jan 2013 15:05:34 -0800, Piet Barber wrote:
What I would really like is a force feedback joystick that closely represents the style of control column you see in real life gliders. Something that doesn't sit on a table, but is positioned on a chair, and be grabbed in the customary fashion that a normal flight control stick is grasped. And something with a mini-throttle built in that I could use as a trim-tab. I don't need all those 85 buttons and control hat that all the modern joysticks have. If you can find something like an old CH Pro gaming stick (two buttons on the stick, throttle wheel and X and Y trim pots it shouldn't be too hard to adapt it. Make a stick of the right length from alloy tube and mount it on a box or whatever so it has the right relationship to your chair. Fit a mechanical link from your stick to the the CH Pro stick so it will follow your stick's movements. Take the handle off the CH Pro and put it on the top of your stick and wit up its two buttons in case you find a use for them. Lengths of bicycle brake cable can be used to connect home made brake and trim levers to the throttle and trim pots on the CH base or use that sort of linkage to make the throttle into an airbrake and build a mechanical trim setup with springs on the stick (would be more realistic since the CH trim pots don't physically affect the position of its stick). Of course, the CH Pro is an old-style stick that plugs into a game port and it may be hard to find a game port adapter to fit a modern PC. However, I bet you could do a similar butcher job on a cheap modern USB stick and simply discard all the buttons etc you don't need. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
Condor Thanksgiving and Condor Christmas Contests | [email protected] | Soaring | 0 | October 22nd 12 03:33 PM |
Condor Joystick/Rudder Pedals | Peter von Tresckow | Soaring | 5 | January 4th 12 04:08 PM |
What's the best PC joystick? | John Doe | Simulators | 5 | June 11th 06 06:01 AM |
good joystick/rudder/throttle choices for MS Flight Sim 2004 on XP | [email protected] | Simulators | 5 | September 3rd 05 10:29 AM |
Which joystick | Oysters8 | Simulators | 3 | February 15th 04 01:36 PM |
