On Sunday, January 13, 2013 8:29:52 PM UTC-5, Bastoune wrote:
All, My radio (Dittel FSG 71) Squelch seems to be a bit sensitive (but by design, cannot be adjusted by the pilot). In my case, when flying, the squelch is a bit sensitive and the “white noise” of the radio comes on at times, even when there are no communications received. I can always reset the Squelch by pressing and releasing the PPT button. The radio then goes silent for a while until a real transmission is received, or until the sensitive squelch problem reappears. I cannot reproduce the problem on the ground. I have noticed that the problem gets worse when I connect my PCAS MRX to the 12V bus of the aircraft. The problem is not as bad when I run the PCAS off AA batteries. I have also a vario+pda connected to the same 12V battery bus. - Can the Dittel FSG71 squelch be adjusted internally? (it can not be done externally via a knob) - If my other equipment connected on the 12V creates noise, can I install a capacitor between the power leads going into the radio to reduce the noise? - What else could be the source of this nuissance? Thanks, Bastoune Note: I have another radio related question but will post it separatly. I can't help with the Dittel squelch adjustment, but I can confirm that some Zaon MRX units will create noise when it is operated with external power. My older one did not, but my newer one sure did! Played a little with filters and chokes, to no avail, and finally sold the MRX. Good luck! -John, Q3 |
Dittel FSG-50 Adjustable Squelch Modification | Jim Vincent | Soaring | 2 | April 13th 11 08:45 PM |
Dittel Radio | [email protected] | Soaring | 11 | January 27th 09 09:09 PM |
Static/Squelch Noise in Radio | Kensandyeggo | Home Built | 2 | April 13th 06 09:00 PM |
Radio "Squelch-type" Noise | Kensandyeggo | Owning | 7 | April 12th 06 07:20 PM |
Dittel radio Q | ken ward | Soaring | 1 | October 8th 03 07:23 AM |
