On 3/23/2013 11:43 PM, Wayne Paul wrote:
Tim, This thread brings back a lot of memories of the advice I was given when I purchased my first Schreder sailplane, most of which was erroneous. I only had about 10 hours in a Ka-6E prior to purchasing an HP-16. Snip BTW, the HP-14 has the most powerful flaps of all the flap-only gliders. Bob, do you really think a '14 with the flaps set at 90 degrees would float in ground effect the length of a 4,000 ft runway? http://www.youtube.com/watch?v=PXwy7dsLndM Wayne Moderator Yahoo hp-gliders news group Webmaster Schreder Sailplane Designs website My observational/PIC experience matches Wayne's claim above...i.e. I've never encountered a flaps-only glider with more powerful flaps than an HP-14. As noted elsewhere, my PIC experience includes C-70, HP-14 (short span, long-flap version), & Zuni. My observational experience adds 1-35 (retract & Club), PIK-20A/B, HP-16, HP-18, AS W-20 (all have spoilers, but I'm referring to the large flap-deflection versions here), Monerai and possibly a few more I'm forgetting. As to the question, "[D]o you really think a '14 with the flaps set at 90 degrees would float in ground effect the length of a 4,000 ft runway?" my short form answer is, "Yes." Reason? The "float tendency" is "excess speed dependent." Every flapped ship I've seen and flown has exhibited similar behavior in ground effect with full flaps...a *marked* decrease in apparent drag and increase in "floating tendency." The more "safety speed" Joe Pilot brings close to the ground, the (rapidly) worsening the tendency to float. I've no idea how much "excess safety speed" an HP-14 might need before it floated off the end of the runway compared to (say) a 1-35, and it would certainly be more than required by a 1-35, but my takeaway point for folks considering transitioning to large-deflection flaps-only ships is "excess safety speed" carried through the roundout, likely won't be increasing their immediate future's safety. Like practicing inadvertent departures from controlled flight in the landing pattern, my recommendation for carrying "excess safety speed for Mom and the kids" in these ships, is; "Kids, don't do it." That said, if anyone DOES find themselves floating undesiredly and rapidly toward the far end of the runway in full-flapped ground effect, I'd next recommend they simply begin reducing the flap setting as rapidly and "pitch steadily" as possible, because their 3 remaining reasonably safe options are now: 1) float with full flaps until the end of the runway or touchdown, whichever arrives first; 2) reduce flaps/settle/touchdown/brake as heavily as possible/groundloop if necessary; or 3) initiate the groundloop while still aloft (Yech!). My recommendation is option 2, based on the float lengths I've seen (always by other pilots) vs. the effectiveness of "typical glider wheel brakes." Stated another way, if conditions require "excess safety speed" (and any transition-to-a-new-ship day, shouldn't), I'm a believer in getting rid of the excess speed where it's safest to do so (duh! ;-)), which - IMO - in a flaps-only ship is (for discussional purposes) in the "final 15 or so vertical feet (and not the final vertical 3 feet). I never botched things so badly I "dropped in" from a personal "fright height" either the C-70 (PIK-20-like flaps) or HP-14. In both ships, even a botched (too rapid) roundout with full flaps resulted in sufficient downwash from the flaps that - when I simply halted my aft-stick movement the instant I recognized a "serious balloon" - the ships ultimately settled to earth relatively gently. My guess is my worst such "drop in" may've been from 2 feet or so, but I don't know. I know it SEEMED much higher, but I never had anyone from the peanut gallery tell me afterwards they thought I was going to bust the ship or my back. The Zuni I did (twice? thrice?) "full-flap drop in" from sufficient height I was worried for the ship...because - due to its relatively weenier flaps, drag and downwash - it ballooned higher more rapidly before I caught it, and once at the top of the arc, there's nothing one can do but (if sufficiently bold) continue increasing aft force until critical AoA is reached, or, simply wait (and count on downwash to cushion things...this is what I generally did). Reducing AoA with forward stick "trying to maintain (reducing) speed" isn't desirable. (Ask me how I know.) - - - - - - For anyone reading this while in a position of considering transitioning to a large-deflection landing-flap-only ship, understand I'm touching upon something that is completely - and entirely safely - avoidable simply by not carrying "excess safety speed" in such ships. My experience - both PIC and as a member of the peanut gallery - has been that none of the nuance expressed above will be "necessary" if Joe Glider Pilot simply flies his approaches in such ships using the usual "generally accepted by competent and knowledgeable instructors" rules of thumb for choosing (in the absence of manufacturer recommendations) an approach speed sensible to that needed to transition to any new-to-him spoilered ship. In broad brush terms, arguably the WORST thing a wannabe large-deflection landing-flap-only transitionee can do - IMHO - is buy into "the intimidation factor" so prevalent in the free advice world. Why? Because much of the advice therefrom is not only confusing, contradictory and unnecessary, but actively harmful. Coupla examples spring immediately to mind (in no particular order)... 1) Big Intimidating Pitch Changes Required!!! 2) Not Enough Energy to Round-Out!!! 3) In Speed Lies Safety!!! 4) Reduce Flap Setting at the Risk of your Life!!! 5) Difficult to Judge Glide Path (because of pitch changes)!!! I'm probably overlooking some others, but just to quickly attempt to provide a measure of sensible counterpoint to the above canards... 1)Better not fly a Schweizer 1-34 or 2-32, then... 2) Utter rubbish. (I used to regularly fly "back of the polar curve" approaches in my HP-14 in calm [e.g. late evening] conditions, and not once felt I was marginal on roundout energy. In fact, the slower the approach, the more time-available/easier-it-was to assess precisely when the final roundout should begin.) 3) Discussed above. 4) Nonsense. Pitch falls out in the wash of airspeed control, regardless of the ship being flown. (As noted elsewhere in this thread, vertically gnarly pattern conditions in the weenily-flapped Zuni regularly occasioned the need for this technique. In the [far more draggy HP-14] I once dumped full - hydraulically actuated, "instantaneously"-dumping-by-air-pressure, flaps at ~300'agl on short final during a thunderstorm approach because I WAS going to overshoot due to "cloud suck", and did a go-around. In my judgment the risk associated with the overshoot (deep ravine on the west side of the old Black Forest E-W strip) exceeded the risk associated with dumping the flaps, and the low-starting-altitude go-around. By far the greater risk in the option I chose was the go-around bit, not the flap-position-change bit, but at least a failed go-around would have me contacting level prairie instead of a tree-studded ravine. For the record, I never should have placed myself or the ship in that day's position...) 5) More nonsense. (The steeper the approach, the easier judging one's roundout point becomes. The time delay establishing the new, speed-stabilized pitch/flight-path change coincident with your new flap position was probably no more than 2 seconds in the HP-14 [whose flaps came down ~20-degrees per pump of the hydraulic handle], and with each pitch down, the roundout point became more easily identified..not that it ever was difficult.) RAS is (probably) a lousy place to discuss stuff like this, but being someone more inclined toward accuracy than toward "good hangar tale hyperbole/inaccuracy," I occasionally feel the need to attempt to limit the spread of less than informative, and sometimes outright unhelpful, contentions. I'll go take my meds, now... Bob W. |
Pros and Cons of a 501(c)(3) Operation | Randy Teel | Soaring | 4 | March 7th 12 03:39 PM |
Starduster One pros and cons | [email protected] | Home Built | 11 | November 2nd 06 07:37 PM |
Starduster One pros and cons | [email protected] | Piloting | 2 | October 29th 06 06:40 PM |
AUTOPILOT PROS & CONS | STICKMONKE | Instrument Flight Rules | 53 | May 23rd 06 11:16 PM |
GPS Models -- Pros and Cons | Aviv Hod | Piloting | 22 | July 22nd 03 10:35 PM |
